Question about Whirlpool Washing Machines
Hi my washer machine recently water back up from detergent draw. Can you tell me what is the problem?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Do you know the model number of your machine?
Posted on Dec 31, 2010
Hi, I have a Asko W6221 washing machine. It is about 6 years old. Just recently it has started to leak water/washing detergent down the front of the machine, from the gap that is located underneath the...
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Aug 21, 2008 | Asko Washing Machines
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Control locked light on no buttons work
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water runs out of the detergent compartment when the washer is filling.... what is the problem?
probably soap blocked at back of draw, remove draw and clean out, there is also normally a small pipe where the conditioner goes in and this tends to block
Dec 17, 2009 | Samsung WF337AA Front Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Hi.
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Front load washer wsx208a
clean the detergent draw dont put the detergent liquid or bleach over the limit line...should low than that line.
Oct 05, 2008 | GE WSXH208A Front Load Washer
Water in detergent dispenser
I think this is normal. Mine does too.
Jun 21, 2008 | LG WM2688H Front Load Washer
Washing Machines Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal De
