Question about Casio Exilim EXZ90 121 MP Digital Camera Available in Black Silver or Blue KIT includes Camera
The power won't turn on. If I get the batteries out and put it back in, it has the slight possibility it turns on but next time I turn it off it won't turn on back again.
    Master:
  • 340 Answers
I think that, maybe the connect between your casio camera battery and the battery box is not so close, have a clean of the connect chip maybe get better. Have a try and see anything help?
Posted on Dec 31, 2010
Tv won't turn on
Hi, If you have checked all connections. The next thing would be (power supply) in back of set. You may have to take it to a repairman since they have all tools and parts for this. Good luck.
Oct 24, 2012 | Televison & Video
Dead battery on 2000 clk 320 , after checking oil and plugs . first attempt to start click'd but did not turn over. Next i turned the ignition all the way off then on, it started. Next day, dead.
Well, first, the battery is not dead. You could have a poor electrical connection somewhere between the battery, starter, ignition switch, or another component of your start circuit, or possibly a failing starter solenoid, or ignition switch. Some electrical testing will be necessary to find the problem. A quick check the next time it won't crank over, is to pull the starter solenoid wire off and check for power on the wire when key is held in crank position. If power then, probably a failing starter solenoid. If no power there, then you have to diagnose the start circuit back through the ignition switch to the battery. Are all your battery and ground connections clean and tight? Starter connections? Use process of elimination, use care, and you'll find the problem.
Sep 25, 2012 | 1999 Mercedes-Benz CLK
I have pavilion dv7 won't turn on
First, To put the laptop to charge the battery for least 1 Hour, if continue won't Turn on , apply botton power and ESC and active the troubleshooting its possible that ypour battery is die,
Jun 21, 2012 | HP Computers & Internet
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
I put in fresh batteries but the calculator won't turn on.
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-83 Plus Calculator
My student's ti nspire won't turn on. They have the 84 face plate on it.
Put in new batteries and try again.
Regards.
Sep 12, 2011 | Texas Instruments TI-Nspire Graphic...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
My compaq presario cq60 won,t turn on. the power light next to the charger cable is on but it won,t turn on
The charger is functioning well. There are still two possible reasons why your computer is not turning on. 1. The battery, 2. The computer itself.
What you need to do is to isolate the problem.
Here's what you can do to isolate the problem.
1. Remove the battery from the computer.
2. Turn on the computer using the cord. Remember not to put back the battery yet. Just the cable and the computer connected. If the computer turns on, then, you need to replace the battery.
3. If it still not turning on by using the cord alone. Try to wiggle the cord to check whether it's loose or not. Check if there are some signs of power on the computer. If there is a power like lights lit in the computer, then, it's the computer that's having the problem. You need to bring it to a technician if that's the situation.
Please let me know if there are any development after doing the troubleshooting above so that I can get back to you if you need my help.
Thank you for using fixya.com
CARLO
Apr 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Casio Exilim EXZ90 121 MP Digital Camera Available in Black Silver or Blue  KIT includes Camera Logo
37 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
