Question about Magellan Maestro 4250 GPS
Where is batter located and what size do you need?
    Problem Solver:
  • 6 Answers
The battery is inside the case under the logic board.
To get at you will need a very small phillips screwdriver and a very small prie tool (Spectical flat screwdriver will do).
1/ Place your unit screen down on a towel (Prevent scratching the screen)
2/ Remove the small rubber plugs on each corner. There are 4
3/ Remove the 4 small phillips head screws.
4/ Now the tricky bit with the prie tool or small flat head screwdriver. pop it into the sides
gently and pop out the locking tabs, work you way all around (there are two on each side).
Be gentle doing this as the electronics inside here are very delicate.
5/ OK now the back is loose you will need to unplug the speaker from the logic board. Now
the back can be completly removed.
6/ There are 2 screws holding the logic board in place 1 on the left 1 on the right. Remove them.
7/ Now on the side were you put your SD card in apply gental pressure to push out the plasic and at the same time lift out the logic board, remember to lift up the microphone at the top left.
8/ Wala theres your battery it is taped in place so gental pressure will be needed to lift it out
Unplug and replace rebuild is the reverse of stripdown.
Once you put it all back together you will need to charge it for at least 4 hours.
Good luck hope this helped you
Peter
Posted on Dec 31, 2010
I need to replace the batter in my nixon custom sometimes naughty watch. How do I find out what size battery to use?
Take your watch to a jeweler who will open it and identify the battery type and replace it.
Mar 27, 2017 | Nixon Watches
Where is the CMOS batter located
The CMOS battery will be on the motherboard. Remove the cover then sit the computer on it's side. Take a flashlight and look for a silver battery about the size of a nickel. Once you find it, use a very small flat head screw driver to pop it out. The normal size battery is CR2032 which can be purchased for less than $5.00 at Walmart, your grocery store or a drug store.
Mar 22, 2012 | Computers & Internet
Need Manual
I found only one other reference to cleaning this model on the internet and that TWB2 did not have detachable plates. You should not immerse this. I generally do not clean the "Teflon" surface of waffle makers - leave it oily. I do clean the outside with a damp soapy sponge.
My experience with waffle irons is that you should lightly oil the inside (spreading everywhere with a boars hair brush) just before adding your first waffle batter. Even non-stick surfaces need a little oil.
>>My Waffle Tips: The batter should contain more egg and oil than a pancake batter does. If your waffles are too chewy, you mixed the batter too much and made gluten. The egg whites should be beat separately to stiff peaks and folded gently into the batter. The batter should be quickly spread across the lower griddle, filling every void. Pay attention to the amount of steam coming out of the griddle and the smell - this correlates to the moisture content of the insides and the crispness of the waffle outside.<<
May 21, 2010 | Toastmaster TWB2 Cool Touch Belgian Waffle...
162-system option not set cmos checksun invalid, default values loaded
The cmos (bios) batter has gone.It's the size of a tablet and costs about two pounds (5 dollars, 3 euros, etc) but it's hard to replace unless you know what you're doing. The batter is normally underneath the laptop under a hatch, and perhaps under the ram memory, or hard rrive, or wireless network card.
Nov 26, 2009 | Compaq Armada 4130T Notebook
Are the barreries ina 01 and 05 accord interchangeable
Providing the physical size of both art the same and the posts are in the same locations, check the cold cranking amps on both (should be printed on label . if similar, (a 25 difference isn't much) either should work in both cars.
Jun 21, 2009 | 2001 Honda Accord
Bious setup
You pretty much need to Reset the bios.
To do this follow the following steps.
Shut down the computer and unplug it
Open the computer case
Locate the CMOS battery this is a circular button batter about the size on a nickel and will have CR 2032 on it
While having contact with the metal case remove the battery for about 5 min 10 to be safe
Replace that battery and reconnect the power cord
reboot and Hopefully when you go in to bios there should be no password
Let me know if this helps if not there is another way that certain boards need but i find this the best and easiest way for most.
Jan 31, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Bios setup pasward
Jan 31, 2009 | Computers & Internet
Locating the batter AAA 1.2V in Malaysia
Actually in Malaysia 1.2V AAA batteries available in most gadget stores and even in supermarkets. You may also get on local eBay website. www.ebay.com.my
Jan 07, 2009 | Panasonic KX-TG1033S Cordless Phone
SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Oct 24, 2007 | Sony VAIO FX150K Notebook
Magellan Maestro 4250 GPS Logo
152 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
