Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
I tried to connect to wifi on my new xbox slim, when it said that wireless mode not connected.i looked it up for solutions and nothing worked,Also i have the new slim and the old 360 elite console, and my new slim is very slow and usually wont let me download dlc for game because it will freeze at a certain number.It wont let me recover my friends account, but on the elite console it recovers fast.So my new 250 gb xbox is slower than my damaged xbox elite system (120 gb)
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
  • 31 Answers
SOURCE: console moved while game was playing hence ring on disc and disc freezing any solution instead of throwing away
ive had this happen to me a couple times, no where can clean it but you might be able to get a replacement
Posted on Sep 30, 2008
webdevil
  • 43 Answers
SOURCE: cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Posted on Jan 05, 2009
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
  • 3 Answers
SOURCE: xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Posted on Feb 23, 2009
Cant hook xbox 2 wireless router
I'm going to assume that you are talking about the New Xbox 360 Slim that has wireless capabilities. You must go into your settings and go to the network settings. When you choose to connect wireless-ly, choose your routers signal, and if it has a passcode you must enter this in to connect to your router. If you are using the older "fatboy" xbox, you cannot connect to a wireless router unless you purchase the xbox wireless network adapter. Please note that you cannot use the wireless network on the new xbox slim if you have a network cable plugged into your console!
Sep 01, 2011 | Microsoft Xbox 360 Console
How do u connect an an xbox 360 to xbox live
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
Aug 24, 2011 | Microsoft Xbox 360 Console
How do I hook up the WIFI for the xbox if all I have for a computer is a netbook with a wireless router.
If your NetBook has been configured to interface with the wireless router, then use the same SSID and password to configure the XBOX to connect to the wireless router.
Dec 12, 2010 | Microsoft Xbox 360 HardDrive 250GB Slim...
How do i wirelessly connect from a pc that has built in wi fi to the new xbox 360 slim that has a builtin wi fi
The two wifi's have to be syncronised together.If they are operating on a different wavelength or frequency they won't connect with each other.If you have a disc(installation disc) for both reinstall both discs seperately and then retry.
Aug 07, 2010 | Computers & Internet
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
Trying to connect my PSP to wifi but it says connection error
firstly check the wireless mode on your PSP - is it on or off
Oct 20, 2009 | Sony PlayStation Portable (PSP) Slim...
Connect to wireless
I believe the X-Box does NOT have Wifi built in? (sic)Surprisingly, the Xbox 360 doesn't have wireless networking built in. If you don?t fancy using the wired Ethernet method, you can invest in a wireless networking adapter. Microsoft has its own adapter specifically designed for the Xbox 360, but third-party Wifi-certified devices will work just as well.(sic) From the below site. http://72.14.253.104/search?q=cache:d7LlkY7Zo1sJ:www.vnunet.com/personal-computer-world/hardware/2147007/microsoft-xbox-360+xbox+360+wifi+is+built+in%3F&hl=en&ct=clnk&cd=2 So that may be ya problem?
Aug 12, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
