Question about Acer Aspire 5600 Series 5630-6951 Laptop
Keyboard stucked hello there..i have a problem with keyboard when i turn on my cam...is getting stucked..i have turn it off from power button..sometimes is happens after 5-10 mins, sometimes straight when i try to open something......when i have my cam off my keyboard works fine..the problem is only when i turn on my cam.....i use vista and i did system restore, antiviruses, antispyware, diskcleanup,i dont have drivers conflicts...please help me.....i dont know what else to do.....ive been searching online on different forums..i couldnt find my answer......tho sometimes my touchpod is getting hot but the cooler is working ok....no loud noises...please help......thank you
    Scholar:
  • 32 Answers
This is not necessarily a one shot fix all, but, I would kind of relate this either to an overheating issue or a BIOS/North Bridge error. I would look up a good CD-booting diag software like Eurosoft's PC Check. do a full diagnostic of all your hardware, including the USB ports. You can also attempt to download more recent software from the webcam's manufacturer. Another simple check is to try someone elses cam on your pc to see if the same problem exists. It could be something as simple as the software you are using your cam on.
Posted on Jul 08, 2008
Lenovo R400 Error 0210 stuck key 5b
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Aug 19, 2016 | Lenovo ThinkPad R400 Notebook
Tape is stuck
Tapes commonly get stuck in cam operated transports. The belt gets too lose and can not turn the attached cam gear- it is easy to release a tape- you open the unit up and remove the power first. Find the pulley that has a loose belt on it and turn it by finger- do not apply a lot of force just about what the belt would do. At some point the deck will open. Then you can remove the tape.
Jan 31, 2012 | Pioneer Audio Players & Recorders
My phone is frozen! It is stuck on this msg. "Samsung SGH-T249". No matter which button I push, nothing happens. It will not turn off, nor can I make outgoing call. The screen stays...
Press and hold the power button until the unit turns off. Sometimes it takes up to two minutes to turn off. If you cannot get it to turn off using the power button, open the back and take the battery out. Press and hold the power button for sixty seconds with the battery removed to reset the unit. Then reassemble it and turn it on. This may not solve the problem on why your screen is getting stuck but it will reset and allow you to attempt to restart it.
Aug 16, 2011 | Cell Phones
Brand new computer-keyboard does not work
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
Have nice day :)
Mar 13, 2011 | ASUS 90-A4C1K1000 Keyboard
My Logitech keyboard worked perfectly last week, but when I came back from my friend (I had my keyboard there, for the third time) it didn't work perfectly after 1 day, it started typing randomly but when...
When my logtch does that is usally is a stuck key. It can also be a low battery or the antenna is too close or too far away.
Most of the time its a stuck key. turn it upside down and knock on it like you are knocking on a door. that usually will jar the keey loose. you may be able to find the stuck key by pushing on them and see which one doesn;t pop back or feel right. Don;t try to pry it loose do the knock.
If the battery has just enough power left you can get some wired things happening but usually it just stops working.
Move the antenna so that it is about a foot away and is clear line of sigt from the keyboard to the antenna. You may want to reset or reconnect using the button on the antenna and the bottom of the keyboard.
9 out of 10 times its a stuck key.
Dec 02, 2010 | Logitech Cordless Desktop MX3200 Keyboard...
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
Some key of my sony laptop is not working properly ,p is replacing theprevious word.backspace & delete key is not working.
if this just happened, it may have to turn off the laptop, remove the battery and adapter, then press and hold the power button for about 10 secs to discharge residual power, then reconnect the power sources and test the keyboard again. If this did not work, confirm if an external keyboard is working. If no issues with an external keyboard, you may try to remove and reconnect the keyboard cable connection to the motherboard, make sure none of the keys are stuck, and if nothing works, you may have to get a replacement for it.
Sep 01, 2010 | Computers & Internet
Does not boot makes a clicking sound
You have a key stuck on the keyboard. Unplug your keyboard turn the computer on if it it gets past the post, then you need to find which key is stuck. If the keyboard is usb then you can plug it in when you free the key. If it is PS2 style you can shut off power right after it starts with out clicking. Once off key freed you can turn it back on. If key is not findable replace keyboard. After verifing no keyboard no clicking.
Jan 15, 2010 | HP Compaq Presario SR1620NX...
Turning On and Off
Is your panel actually powering down or is the back light going on and off? That would be a more serious issue but let's try the simplest thing first. Make sure your Remotes Power button isnt stuck down. I have seen this happen before and it will just keep sending out power commands toggling the set On and Off.
Take the batteries out of the remote and see if it continues to do that. Sometimes the button pads get stuck down.
Jan 06, 2010 | Fujitsu Televison & Video
Acer Aspire 5600 Series 5630-6951 Laptop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
