Question about Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
Handle on bottom freezer door is loose. Screw on bottom of handle appears to be neither a philips or flathead screw. just seems like a teeny tiny rivet.. Inside the handle is a floating "ball" with a reular screw that I cannot get ahold of to actually screw back in the hole. Help!
Thanks to Dana; it was a 5-star screwdriver, which I was fortunate to find one in my collection of tools and solve the problem. 30 minutes to figure out it was a 5-star screwdriver and find the tool; 3 minutes to fix the handle!
Posted on Aug 15, 2012
    Problem Solver:
  • 12 Answers
Hello, You need to look at the screw at the bottom of the handle. I know this is difficult to do; however, you have to establish what type of inset screw you have to faster. Most probably, it is a four or five star screw. You have to have a certain head screwdriver in order to turn the screw in order to secure the handle. When you identify the head of the screw -- as in four or five head screw -- place the screw driver into the screw and turn until it is firm.
If this does not work, refer to the manufacturer's manual to find a solution.
Hope this works for you. Dana
Posted on Dec 31, 2010
The door handle has become loose and I want to know how to tighten it
They are two hinges one at the top and the other at the bottom. Use a philips screw driver to tighten two screws at the top and two at the bottom. The bottom screws require a dumpy screw driver (short).
Jun 16, 2015 | AEG Santo 70342KG Bottom Freezer...
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Maytag Ice20 freezer door handle fell off on one side
I had the same thing happen with my freezer door on my Ice20 as well. You need to look inside the hole on the inside of the handle on the end that has come off. There will be a loose screw head sitting in there. You need to get that out and screw it back into the hole in the freezer door. Then, place the handle back on top of the screw that you just put in. Make sure the screw head is sitting properly inside the hole in the handle and the handle is flat to the door where it should be. Now, using a small set of allen keys, find the one that fits in the tiny hole on the underside of the handle. There is a little thread in the hole and you need to use the allen key to turn the thread until it puts pressure on the screw. This keeps the handle on. I was able to fix my door with a 40 cent allen key. Hope this helps!
Mar 18, 2011 | Maytag Refrigerators
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
How to tighten freezer handle
There are two screws in the top of the door and a cap that needs to be removed with a flathead screwdriver to access the other screw on the front of the handle
Nov 20, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
124 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
