Question about Hitachi 500GB 7200RPM 16MB BUFFER SERIAL ATA II/300, 3.5INCH, 8.8MS SEEK, DESKSTAR P7K50 500 GB Hard Drive
I installed a hitachi 500gb hd in my computer using a serial ata cable , but when i turned the computer on I get an error message "Reboot and Select proper Boot device or Inster Boot Media in selected Boot device and press a key" what is this about? Thank you
    Novelist:
  • 108 Answers
There is a series of phases the computer goes through before it tries to boot an installed operating system.
It sounds like your computer can start and does recognise your new hard drive, but dosn't look or recognise your original drive any longer. This is certainly the case if you remove the new drive, and the computer works like it's expected to.
The second thing is recognising which drive to boot from. This involves going to the BIOS settings, which is reached by pressing a magic button, while your computer is first starting up. It's different for various manufacturers, and sometimes displayed on the screen when the option is available, like "Press F2 to enter Setup" or something similar. My Computer says "Press F11 to go to setup; Press F12 for Boot options". The most common keys, if your computer isn't so forthcomming, are F2, F6, F11 and F12. Press all of these, (one at a time), soon after starting the computer, and you'll probably end up in the BIOS Setup.
In the BIOS setup there are options for the available "Drives" on your computer, with SATA capable BIOSs each drive port, (SATA plug), available has it's own page with options and explanations. Check that your original drive is Enabled still.
There should be a Boot Options page, where the available boot media is listed in the prefered priority, like (CD Drive, Floppy drive, USB drive, C: drive, D:Drive, etc.), on this list move your original drive, (May only be listed as the manufacturers number), to the top of the list.
Save the Settings and exit to reboot with the new settings.
Hopefully this leads to some solution.
Cheers.
Posted on Nov 04, 2012
  • Richard Schabler Nov 04, 2012
    One additon, perhaps the quick fix, is to be sure you have a power supply connector plugged into each hard drive, and that the data cables and power connectors are plugged in all the way. SATA cables do slip out at times.
  • 591 Answers
Your computer is trying to boot from the new istalled drive instead of the drive containing the operating system,
you could try swapping the SATA cables on the mother board, or enter the BIOS by rebooting and at start up, holding the correct key (acording to the manual) then look for BOOT DEVICE some where in the BIOS menu, change the boot device to the correct hard drive (the one containing the operating system)
Have fun!
Posted on Dec 31, 2010
I am replacing a Hitachi Travelstar 5K100 HTS541080G9SA00 80GB with a Western Digital 500GB SATA 3Gb/s Hard Drive 8MB 5400RPM 2.5IN Scorpio Blue. A tech told me to use a cloning software to switch the...
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Sep 20, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
I have a 500gb Hitachi sata drive on a gigabyte GA-Ma78gm-s2h mb that ramdomly goes offline. Takes shutting down computer and restarting to bring back on line
well this normaly happen if you have more than one drive on your computer and in order avoid this problem change the power supply settings inthe control panel to always on scheme.
Good Luck.
Jan 07, 2010 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
I am trying to install a Maxtor Basics 500GB External Desktop Hard Drive and cannot see the drive on my PC. I'm assuming it is not installed. I operate a Windowss XP Platform. Help!
Right click on my computer and go to manage, then go to storage, disk manager and see if the disk shows up there, you may need to partition it first, you can make one partition of that hard drive. If it is not in there, check the jumpers and make sure it is not the same as the main HD. The main drive should be master and the second drive should be slave, or make it cable select and do it in the bios.
Jun 21, 2009 | Maxtor MaXLine Pro 500 500GB 7200rpm...
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Can't format HDD
Hey, please try to diconnect and reconnect the CD/DVD drive and check if this works.. Some times installation is incomplete if the file skip during installation.....
Feb 18, 2009 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
Copying data
click on the drive once so it highlighted. Hit the 2 keys apple and I. this will bring up a dialog box with the drives information. See if the drive is locked. Choose ownership and permission below and click on the padlock, you want read and write permissions and you will only need your system password to change this. Also check if the drive is formatted properly for Macintosh use. If there is nothing on the drive that is crucial, open DISK utility and format it for OS extended.
Oct 17, 2007 | Maxtor MaXLine Pro 500 500GB 7200rpm...
Hitachi 500GB 7200RPM 16MB BUFFER SERIAL ATA II/300, 3.5INCH, 8.8MS SEEK, DESKSTAR P7K50 500 GB Hard Drive Logo
140 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
