Question about Poulan Garden
I have a second hand Paulan model 3616 chainsaw . Can you tell me if it runs on straight unleaded petrol or two stoke fuel ? If two stoke what is the mix of oil to petrol ? Thanks
  • 784 Answers
That Poulan saw is 2-stroke and needs a fuel oil mix ( 2-stroke oil ) at a ratio of 40:1.
c...
Posted on Dec 31, 2010
  • 395 Answers
I am not familiar with the model No. but most chainsaws are Two Strokes and require a fuel & oil mix. The fuel tank cap should indicate by symbols or words the fuel requirements. If unsure call your local agent or chain saw retailer.
The standard Fuel / Oil mix for most two strokes is 25 : 1
Can I use a 50:1 fuel ratio to run my mcculloch 35 cc chainsaw?
Yes... but use a good quality 2 stroke oil. Only use unleaded fuel and never ethanol based petrol.
Apr 22, 2017 | McCulloch Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
Proper fuel mixture for Dynamac DY 51?
you would be safe to run a standard 25:1 mix 200ml of 2-stoke oil to 5 liters of petrol/fuel/gas.....(5000ml divided by 200ml= 25) most 2 stoke oil is able to run at 50: 1 mix ...instuctions on what oil ratio should be used are always displayed on the oil bottle you buy for aircooled 2 stroke engines....
Dec 03, 2013 | Garden
What cuases valves to burn in an engine
Weak mixture is main cause ,but what is the psec on this engine as modern fuel is unleaded and if this is a 1990 then it could have been made to only run on leaded petrol ,unleaded engines have a stelite coating on the valve and the seat in the head to run on unleaded fuel ,or the valves have been ground in more than once and the coating has been worn away .Check with the dealer if this model is designed for unleaded fuel ,if it has a cat on it then its designed for unleded fuel
Mar 23, 2012 | 1990 Toyota 4Runner
What kind of oil do I need to use in my husqvarna 16" chain saw?
Unleaded fuel with Husqvarna two stoke oil mixed at 50-1, for the chain you need a non fling chain oil, both should be available from your local Husqvarna dealer.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Can 94 jetta run on leaded or unleaded petrol
It is best to run this engine on unleaded petrol. A high grade unleaded will give you extra performance and cause no damage. Leaded fuel was designed for cars made in the 60's to 80's that had used softer materials in their cylinder heads, leaded fuel pro-longed cylinder head life and reduced pre-ignition. Unleaded fuels are a cleaner, safer fuel to use.
Jan 24, 2011 | 1994 Volkswagen Jetta
Can you please tell if my Honda Civic 1991 model 1343cc can take any unleaded petrol? if not are there any modification I can do to the car to take unleaded petrol? Thank you
you can check the use manuel or call your local honda dealership near by.
they can tell you if your car can take unleaded petrol.
Oct 07, 2010 | 1991 Honda Civic
Clean old petrol can thoroughly
Not to worry, just drain out any old gas, put in a little new gas, shake it a little, pour that out fill it up and use it. If its bad varnished w/ old gas use stuff called Seafoam pour it in, shake it up let it sit over night and pour that out use like normal.
Aug 01, 2009 | Garden
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
230 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
