Question about Pioneer VSX-D908S Receiver
VSX-D908TX 5.1 Home Theatre Receiver (THX) Problem: No audio for 5-10 minutes after switch-on. The speaker relays click in ok so the problem is a muting related thing. If you know of this problem or someone that does i would appreciate a starting point. I am technical myself and have the circuit diagrams but don't wish to have the system off air for too long. Regards Alan Jones
  • 2 more comments
  • sintro Jul 13, 2008
    I am having the same problem, have you found the solution yet?
    It seems to be getting worst, no audio for 15+ minutes then when I switch input, I have to wait again.
  • Alan Jones Oct 23, 2008
    Well i believe i have found the problem, it is the DSP card and to purchase one from Pioneer would cost A$750.00. I could buy another amp for that but it would not be in the same league.
    The problem is wide spread and dsp cards are drying up so repair is the only option. I have corrected the problems i found but need to put the amp back in the system to prove it so a further update is required.
    Regards
    Al
  • Alan Jones Nov 02, 2008
    The problem is IC9374 (PDK042A), IC9372 (TC55V1664BFT-12) and IC9371 (TC55V8128BJ-12) on the DSP card (AWX7433). They require resoldering which is not easy as special surface mount soldering equipment is required, plasma flow soldering I believe was use on my board. I have access through contacts for this so for me it was easy. Not all three IC's may need soldering but certainly IC9374 and IC9372 were big contributors to the problem.
    Hope this helps.
    Regards
    Alan
  • Anonymous Apr 16, 2009
    Same problem of my VSX-D908TX. It has to be waited for over 10mins for warming up.
It definitely is the DSP board. I pulled mine out and it had already been repaired once and it repair work looks exactly like the ones shown here http://excelcier.com/pioneer_vsx-27tx/ .
Currently I can only listen to the radio in DIRECT mode, if i change it to Stereo or other DSP modes it will be silent no matter how long i wait.
How did your repairs go? Can you please let me know how you repaired it?
Thanks.
Posted on Nov 02, 2008
  • 3 more comments
  • sintro Nov 03, 2008
    Thanks for sharing the info. You are definitely right on that one.
    Actually not long after my previous post, I took out the DSP board then resoldered IC9374 (PDK042A) plus the two 0ohm resistors (R9374, R9373).
    I did not have the right surface mount soldering tools, the soldering iron tip was too big to apply any new solder. I cleaned up the soldering iron tip and managed to reheat/resolder all the IC legs in quick straight strokes.
    This seems to have fixed the problem, now the sound kicks in immediately when I turn it on, just like it should. It was definitely worth the effort but too bad I have already placed an order for a new amp.
  • oengfrias Feb 05, 2011
    Thanks for this posts! I have resoldered mine(IC9374) and it worked just fine..i now get sound from my elite when i turn it on.. Really helped a lot! oeng
  • app_3rp12973
    app_3rp12973 Feb 06, 2012
    Thank you!! I resolderd eveything and it works fine!
  • app_3rp12973
    Thank you! I resoldered everything and it seems to work again! Nice
  • thomasn4
    thomasn4 May 14, 2012
    My brother-in-law has one Pioneer VSX-29TX,and it is NO sound. I did reflow solder at IC 9374(PDK042A) and removed 0Ohm resistors at R9372 and R9271 and then installed at R9374 and R9373. But the result is the same as no sound. Any advise is appreciated. Thanks.
    Problem Solver:
You dont have to resolder these chips! just get a fine point tool and drag along each leg and press all solders on reverse side to make them reconnect.
Posted on Sep 08, 2009
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
How to connect my subwoofer to my vsx-405 receiver
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Feb 24, 2012 | Pioneer VSX-405 Receiver
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch while the output was on. Everything else works, including the B speaker outputs. There are only three...
There are independent relays for the speaker A and B switching.Best place to start would be from the relay. When you select A do you hear a click, if not relay is not switching. The circuit involved is a small transistor , a low value resistor ( could be the culprit ) and a shunt diode.
Aug 16, 2011 | Pioneer VSX-305 Receiver
I have a pioneer elite vsx 36tx receiver that quit working. When I turn it on it just hums. It seems like a power supply but not sure.
I have the same receiver.
Do you mean there is an audible hum from the unit, or that speaker output(s) hum?
Let's figure out what DOES work...
Do you get the audible relay click a few seconds after power up?
Does it tune FM?
Can you get the On Screen Display? Settings all ok?
What preceded this? RSVP.
Jan 19, 2010 | Pioneer VSX-36TX
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
Dec 08, 2009 | Pioneer VSX-1018AH-K Receiver
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
Pioneer VSX-D908S Receiver Logo
1,545 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
