Question about Ariens Garden
Question what would cause a Ariens 1340 c not to start, the starter has been replaced, battery is providing plenty of juice?
    Scholar:
  • 36 Answers
There are only three things left to check. The battery cables must be sending the battery current to the starter relay and then to the starter. That is number one is to check to make sure the battery voltage is going to the starter. The starter relay controls when the starter turns on with the key switch. So if the starter realy is not working then there will be no power at the starter when the key is in the start mode. That is number two. And finally number three. The key switch has to have power to it and out of it to the starter relay to work. Trace all of your electrical from the battery to the ignition switch, to the starter relay, and then to the starter. I am sure that you will find the problem that there is not any battery power going to one of these locations. Also make sure you check the fuse. If the fuse is blown, then your starter will not work because there will be no power at the ignition switch. Hope this helps.
Posted on Dec 31, 2010
I need the wiring diagram for the solenoid/1999 16hp hydronamic Simplicity
The two big terminals are one fom the battery and the other to the starter.
The two smaller ones one comes from the ignition switch and the other might just be a ground.
Test becareful is hook the battery and starter wires up; take a wire and stick one on the battery terminal and tap each of the smaller terminals; when you get a click that will and should fire the stater; make sure it is out of gear or it will start. remember that terminal and hook the ignition key to it. check the other smaller terminal is or isn't a ground one.
http://i59.tinypic.com/24xnwk3.jpg
Jul 18, 2014 | Ariens Lawn Mower Universal Solenoid...
Truck wont start
Won't start or won't crank ?
Will it crank in neutral ?
Jan 21, 2014 | Nissan Frontier Cars & Trucks
Having issues keeping the battery charged. Replaced Battery a few months ago and car was running great. Then a few weeks ago I started to notice that if I let the car sit for more than 3 or 4 days I...
I think it's doubtful that your starter is draining the battery. Once your starter is engaged upon start up, it is done with its job, and it is not needed until the next start up. It does sound like your starter is going bad. If all of the electrical parts seem to come on when you trying to start it, it should have plenty enough juice to start it. One possible cheap solution is it could be the starter relay. The relay takes power from your battery and routes it through to your starter. If this isn't working, your starter isn't even getting any juice. I hope this is the problem. I have seen many starters replaced that should not have been because fo a bad starter relay. You would have to Google that info on a Monte Carlo. I could not tell you where it is on any Chevy.
Aug 09, 2013 | 1998 Chevrolet Monte Carlo
When i push the starter button on my 2010 ultra classic Tri Glide Trike it only clicks
POSSIBLE LOOSE CONNECTION FROM THE SOLENOID DOWN, THE EXCITER IS WORKING THATS THE CLICKING, CHECK FOR POWER AT THE POSSITIVE POST OF THE STARTER, MAKE SURE THE STARTER HAS A GOOD GROUND.
Jun 09, 2013 | 2010 Harley Davidson FLHTCUTG Tri Glide...
Engine will not crank, and I've already replaced to terminals on the battery. Plenty of juice from the battery but no start
Very possible bad starter. Do you hear any clicking noise at the starter? You can try taking a long metal rod and smacking on the starter where the solenoid is while someone is trying to start the vehicle and see if the starter will engage at that time. Good luck.
Jan 19, 2011 | 1993 Mercury Grand Marquis
2003 jetta gl manual trans-positive battery and ground starter cables replaced...now have plenty of juice going to starter...but it grinds when i turn the ignition...now it doesn't start at...
I presume you mean 'grinds when I turn the ignition..(to start)'.
If this is so, it's most likely the starter motor 'drive (overun) clutch is faulty.
Either replace the starter motor complete or replace the drive clutch assy on the original.
The latter should be cheaper (especially if you can source a new 'drive clutch' and fit it yourself).
Nov 13, 2009 | 2003 Volkswagen Jetta TDI
2004 A 8L won"t start
starter wont click because there's not enough "juice" to turn it over. this isnt because of the battery as you have just replaced it. it is due to a bad alternator recharging the battery as you drive. if it were only a fuse it would be the solenoid in the starter. but if it had started after you installed the battery then its not the solenoid. solution: buy a refurbished alternator and
Apr 24, 2009 | 2004 Audi A8
Garden Logo
335 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
