Once I turn on the DVD, I can only see couple of second of the screen afterward is all dark, I can still hear the sound. I try to use the LCD on/off button, the screen come back but only last for 1 second, can you please tell me why? It is worth to fix?
I dont know ans for this,but i want to know solution for this,pls help me.....
Posted on Feb 12, 2009
Digital lifestyles model fa2b 32570
Could be a couple of things.
The good news is that the LCD panel is working, albeit briefly.
It definitely sounds like it's repairable, though.
Dec 03, 2013 | Televison & Video
Screen does not lighy
If you look very closely, is there an extremely dark picture, or a solid black screen? If it's an extremely dark picture, you just need a new backlight. If it's a black screen, you either have a bad connection (broken, shorted or unplugged cable), or need a new LCD. Let me know, and we'll go from there.
Sep 05, 2007 | Cyberhome CH-LDV 712 Portable DVD Player
I have sound on my tv but no picture
This sounds like the back-lights have quit working. This is made up with an inverter (ballast) and fluorescent lamps. I want you to try something. In a very dark room turn the tv on and watch what happens to the screen. There is three things that can happen. first the screen will stay completely black. This means the inverter never fired, and this is usually a failed inverter, but sometimes the power supply may fail. there is also a rare time the main module never outputted the signal to activate the inverter, but this is rare because you can hear the audio. So obviously the main is working at least 90%. The second thing that can happen is the screen will light for a split second then go black. This usually means that you have a bad lamp. These lamps are physically locate inside the LCD panel, and the replacement cost exceeds the price of a new unit. You may even see a dark area in the screen. The slight glow will not be uniformly lit through out the screen. Finally the last thing you may see is the screen has a slight glow. This means the back-lights work, but the video portion isn't showing. This usually means the driver board (T-con) has failed. This is probably not available separately, so you must replace the panel to fix it. And like before, the replacement cost exceeds the price of a new unit. One more thing to do when the set is on and in the very dark room if the screen is black, point a very intense flashlight into the screen. Put the flashlight against the lcd screen and see that you have video moving around the glow of the flashlight.
Sep 12, 2012 | RCA 22LA45RQD LCD TV/DVD Combo
Watching TV and it suddenly turns off just like if you had the remote and shut off the TV. We set in amazement for a few seconds and then we turned the TV back on. We had sound but no picture. It was a...
Tv turn on now,does it have a flashes of picture only a few second than dies and than have only sound left?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards are one to the left one to the right both must be replace.The 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 LCD inverter boards for the replacement.
Mar 02, 2011 | LG 50PJ350 50 in HD-Ready TV
My ps3 turns on but won't show up on the tv. it has been plugged in with hdmi cable for the last 7 months and now im not using an hdtv. i plugged another ps3 into the same cables and it came up on the...
Try to press and hold the power button until you hear a beeping sound. Once you hear the beep, do not let go of the power button and wait for it to turn back off. Allow approximately 20 seconds before turning on the system again. Follow the prompt on the screen afterwards and you should be good to go from that point on.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
My sony 32 inch bravia tv always used to make a click sound about 2 seconds after the set was turned off. Now it only makes the click sound once in a while. The screen is dark and it otherwise looks like...
The click is from the power regulator turning on and off. You should always hear the click if that is how it was when you bought the TV. You can check if the TV is still on by seeing how many volts it draws using a Kill-A-Watt meter and matching it up with the specifications listed in the owner's manual. If they do not match, it can either be caused from the power supply board that is faulty or main board that is providing faulty logic to the power supply to turn on or off.
Oct 05, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
How to replace the LCD screen for motorola Razr V3
First it should work when you turn it on.you should always hear a sound then you press a button.if it is dark screening it is your flex cable that need to be replace.Take it to a repair store
Jun 13, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Image dissapears but there is sound
My sister owns this unit, and like other users on this post, her screen quit working on her. She brought it over to me to see if I could fix it before she tossed it out. I first hooked the unit up to the TV with supplied A/V cables to see if the unit was outputting video. The unit supplied video to the TV fine, so I figured the problem was with the LCD screen or the connection from the unit to the LCD.
Like another user on this post, I noticed that the video would come on for a second or two when the small depress button was pressed, but then go blank again. (This button is at just below the LCD screen on the base unit – toward the middle of the base unit. You can see there is a small notch on the LCD screen that fits into this depress button when the unit is closed. This allows the unit to know when the LCD screen is closed.)
Here comes the fix that worked for my sister’s unit – I hope it works for yours also. . .
I decided to reset the screen to the factory settings through the setup menu. This is difficult to do when the screen is blank, so I figured I would have to go hook the unit up to the TV again in order to see the setup menu. Well, I had already put the AV cables away, and I felt too lazy to dig them out again. I decided to just navigate the setup menu by pressing the depress button on each menu, which the second or two of video would give me ample time to navigate the menu. Once I was in the first setup screen and depressed the depress button the screen came on like it had been doing when I was trying to view a movie, but low and behold it did not go off like it had been when trying to view video. Since I was in the setup screen I decided to reset the unit to factory default. I then exited the setup and played a movie. The screen did not go off. I have tried to get the screen to go blank again, but it stays on. It sounds like the problem is not with the LCD screen or its connection, but rather with the operating software of the unit. It is a piece of junk, but it is working for now. I hope this helps with your units also.
I also noticed some users posting a problem with an upside down screen. Hold down the mode button and the screen will cycle through different settings … one of which is upside down.
May 02, 2007 | Polaroid PDM-0723 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
