Question about Philips Magnavox 20MT4405 20" TV
I have a magnavox 20 inch table top tv and can no longer get access to my aux. inputs (avi, etc.). What do I need to do to get those inputs back?
And buy a new lcd tv of the same or larger size screen! No more parts for this Magnavox junk!
Curtis rush rushdata1@yahoo.com !
Posted on Dec 31, 2010
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
How can I set up with my lcd Sony tv
If your home theater receiver has a digital optical input, run a digital optical cable from digital optical OUTPUT on TV to digital optical INPUT on receiver. If receiver is older and only has analog inputs, you can get an 1/8 inch to RCA cable(red/white), and plug 1/8 inch side to an output on back of TV and plug RCA side to aux input(or CD or cassette input) on back of receiver. DO NOT PLUG INTO PHONO INPUT! Either one of those cables can be found at Walmart, radio shack, or best buy, etc. Digital Optical cable is definitely the best choice, but I just used the 1/8 to RCA setup to hook up a Sony led to my brother's early 90's Pioneer receiver(not the ideal setup, but will work). Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
What channel does the tv need to be on to operate the dvd player? The dvd player comes on but it doesn't recognize the button commands on the tv-do no have the remote.
channel 3 or 4. if that doesnt work switch the input on the tv. the input button might be labelled input/source/tv-video or av. if you arent getting a pic while the dvd player is playing look at the back of the tv and see where the cable from the dvd player is going into the tv. it is labelled what input it should be on. ex: video 1, etc. hope this helps.
Jul 11, 2010 | Philips Magnavox 20MC4304 20 in....
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
Can't receive pic and sound with converter box.
Connect the RF output of the Magnavox to the VHF/UHF (ANT) input at the back of the TV. Select channel 3 or 4 on the TV. An alternate is to connect the component output (red-white-yellow) to the Audio/Video In jacks at the front of the TV (the red or the white would be left unconnected) and use the TV/Video button on the remote to select that input.
Jul 08, 2009 | Toshiba 13A24 13" TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a 24 inch magnavox combo that got hit by lightning is there a fuse or reset?
I'm not an expert at all but there is a fuse in the little hatch next to the power cord. Hopefully that'll help :)
Feb 01, 2008 | Philips Magnavox 20MC4304 20 in....
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox RK5556 CH02 27 inch TV
just press the display button untill you see AUX in
Dec 26, 2007 | Philips Televison & Video
Philips Magnavox 20MT4405 20" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
