Question about Water Heaters
Is there a thermostat on my vulcan model number 6809L?
    Scholar:
  • 117 Answers
Every water heater has a thermostat. if it did't then the water would continue to heat until the pop off valve blew. not a good thing. The thermostat is usaully under the front panel and has a dial on it to change settings. Note that some newer water heaters have an electronic thermostat but still has adjustments.
Posted on Dec 31, 2010
Is this thermostat wiring correct for this Rheem water heater? also it only has one thermostat...shouldnt there be 2?
Heather, first know that most water heaters are 220 volts and are dangerous to work on unless you know that the power is off. Second it is hard to say any more without knowing the model number and the make. Third from the picture, a thermostat breaks the current in one side of the circuit and that appears to be depicted. There are usually TWO heating elements not thermostats.
Feb 09, 2017 | Rheem Water Heaters
Hi my vulcan gas hot water service isn't getting hot enough anymore? please help me?
check first if you have good water flow to and from heater. lift pressure release valve on inlet and allow few sec to flow, same with outlet hot water safety valve.
remove front cover from the heater, you should see your gas connection and thermostat knob.
check if gas is burning evenly and on whole surface, check for leaks on the heater and on the lines to and from the heater.
if you did not find any faults, no leaks, safety valves work correctly, check thermostats settings,
wind it down to minimal, then turn it to about 1/4 value (you did not specify model but this should do, widening arrow or numerical values ar self explanatory), lift hot water safety valve for few seconds, then open any hot water tap (faucet if you are an american...) and check if gas ignites and burns.
set thermostat to about 2/3 value and again, lift hot water safety valve for few seconds, then open any hot water tap. check if gas ignites and if water is sufficiently hot, if too hot - wind it down to say 1/2 way, if too cold, wind it till resistant and then back off a bit, DO NOT EVER LEAVE VALVE OR THERMOSTAT ON MAX!.
if none of these help - you need either, change the thermostat or heater itself.
if works - you solved the problem, close the tap, close the cover and use the system as you normally do.
i am always recommending use of insulation on the hot water system, it saves heaps of money over the life of the system.
hope this will help you - do not forget to vote... :-)
Apr 09, 2015 | Water Water Heaters
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
How do I get fan to shut down auto with no G wire in new thermostat
We need make and model numbers from the unit and the thermostat.
Jul 14, 2013 | Lux Programmable Thermostat Atx500e
Temperature
Pull the thermostat loose from the wall so you can see the model number located on the back of device.
Google search model: xxxxcy .pdf
Or search for british gas thermostat .pdf
This will give you access to product manual.
Also check batteries located on back of unit. Install fresh batteries. Memories should be retained on the chip during battery change.
Add a comment with model number, and I will try to locate thermostat manual.
May 20, 2013 | Water Heaters
Thermostat
Add a comment and describe brand, type and model of product. And what this product does. Is this a thermostat?
Also say if this is new installation or older installation
If you have Honeywell thermostat, then model number and AA battery are located on back of device. Replace battery.
Web search your model number and include .pdf in search parameter to obtain product manual, Use Ctrl+f to word-search manual for troubleshoot section. And view manual for illustrations showing location of battery.
Apr 25, 2013 | Honeywell TH5110D1022 Focus PRO 5000...
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
Water Heaters Logo
162 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
