Question about Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
My Kirby G5 when using Tech Drive does not go forward and back with its own power. The rubber treds on wheels are in tact. I notice the difference between N neutral and D drive being in D is easier to push but only moves at my speed. The vacuum does not go forward or backward with much power. What would you think the problem is?
You need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Posted on Jul 16, 2008
I had same problem with my G6 kirby and the cam had broke off the foot pedal assembly..my vacuum worked fine accept it had no drive so I had to manualy push it which sucked!..heres a link to the part you need.
http://www.repairclinic.com/PartDetail/Pedal/558499/2002216
and heres a link on how to remove it
http://www.youtube.com/watch?v=s0OMCWTAtqg&feature=related
Posted on Jul 04, 2012
Kirby drive wont go in reverse.
The slide will need to be adjusted (may of come loose )
Aug 15, 2014 | Kirby G5 Bagged Upright Vacuum
Kirby g5 self propels too fast
the slide has shifted forward slightly, this happens when the kirby
is hit against walls and skirting boards. you will need a service by your local kirby engineer. see kirby.com for local agent
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Tech drive has no power forward.
Dear Sir:
Download the instruction manual from Kirby, and see the section troubleshooting guide. And proceed according. If you say do not enough power. The batteries can be Not good replace or recharge very well.
Or test the power cord and trafo, and see if the power is o.k or replace. Use the VOM for to test the output voltage.
Another faulty can be the motor some winding inside is overheating and consequently faulty.
God bless you
May 27, 2012 | Kirby G4 Bagged Upright Vacuum
Kirby g5d will not shift into drive
check tech drive sensor, where handle connects to main unit, but you need to open cover off and greese handle slider.
May 08, 2010 | Kirby G5 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
G5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Jul 02, 2009 | Kirby G5 Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Jun 17, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
1,075 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
