Question about Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360
Sensor bar doesn't stay on unless the button is held in.
  • 21 Answers
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook.http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Posted on Jan 08, 2011
  • dogcat12345 Jan 16, 2011
    sensor bar will not stay on can you help
Brake light stays on
No sensor involved , brake lamp switch probably needs to be adjusted ,maybe . Learning to test is the way to a fix ,.not by i was told it could be a sensor . Brake lights stay on Not saying that this is your problem but look under dash at the switch .Check the switch an pedal arm .
Oct 06, 2017 | 1999 Chrysler 300M
Automatic air conditioning auto button will not stay on
temps sensor fault what does the temp read ?
Jun 26, 2017 | 2002 Lexus ES 300
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
My zebra prints blanks. Tried resetting the mode. Turned it off. Held the feed button, turned it on, and when it flashed red I let off. It stays green and doesn't flash again. What am I doing wrong?
My work has the same label printer and when installed had the same problem. be sure that your settings are correct. underr the start buttton on the task bar click on "printer and faxes" find the "zebra 2844 " and right click on the bottom of this sub menu click on "properties" there should be two rows of tabs to choose from click on "printer settings" then select "printer default" on all available ie: fonts, spoolong format, line sub. click "apply" then "ok".
May 20, 2011 | Zebra LP 2844 Thermal Printer
On button won't stay depressed. when pushed to on, the vaccuum goes on but won't stay on unless button is held down.
Needs a new on/off switch. You can order one from an appliance parts store, and replace it yourself or take it to a shop.
Charlie
Feb 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Have re-booted, re-synced numerous times, held red button simultaneously, one at a time, etc. Everything with the remote works except the cursor. Can move to the right and left by using the +/- buttons,...
Your sensor bar is messed up a replacement on ebay is less then $6. Your controllers arent the problems. Also do you have the sensor bar ontop or bottom of your tv? Theres a setting on the wii to change the sensor bar from top or bottom of the tv depending on where youve put it. 99% sure its a bad sensor bar though.
Nov 25, 2010 | Nintendo Wii Console
Soundsticks II power doesn't stay on unless button is held in.
It sounds like a broken switch, there is nothing you can do unless you are confident enough to replace the switch yourself. Is the warantee still in effect. Sounds like a tech is needed to do physical repair
May 17, 2010 | Harman Kardon SoundSticks II Computer...
Need part for H 600T mixer
I dont think the button is the problem.I suspect the side switch on the contactor is bad.Give me a little more info like when the problem started.
Mar 23, 2009 | Hobart H600 Stand Mixer
Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360 Logo
520 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
