Question about Cobra 29 LTD CB Radio
Hi, I have a Cobra 29 NW ST CB Radio and I was wondering something about changing the stock burnt out bulb to an LED. Does it matter which wire goes to the negative side of the LED and which one is the negative one on the radio side of things anyways?? Also, which wire gets the resistor?? Thanks in advance...
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
If you're going to replace a 12VDC incandesant light bulb with an LED, you MUST connect a series resistor in line with the LED and observe polarity as LED's can only be hooked up one way. Depending on the size and color of the LED, An average size red orange yellow or green one for instance, you would use between a 1000, (1Kohm), and a 1200, (1.2Kohm) resistor. These LED's usually require about 1.7VDC at 20 Ma. There are some of the newer white LED's that require feom 3 to 6VDC in which case you'd use a lower value. The blue ones that are somewhat popular now I've had no experience with so get a spec. sheet if you use these.
Good luck.
Jeff
Posted on Feb 09, 2011
    Problem Solver:
  • 13 Answers
LED's do matter how they're installed.
Test your LED leads w/ a batt. first before soldering in you 29 board.
Look at you existing leads from you burnt out bulb. One red?
Then its your Pos terminal. when your LED lights up on your Batt. test you'll know which one is the POS/NEG legs. then resolder it into your board.
Mike
Posted on Dec 31, 2010
I have a cobra 29 wx nw st cb radio I have power to cb and won't power up
is fuse good should be on red wire power or in back of cb itself
Jul 26, 2014 | Cobra 29 LTD CB Radio
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
What size inline fuse is in the cobra 29 wt nw
Usually a 3 amp quick acting 3AG fuse---do not use the generic ones from Radio Shack.
If the radio got hooked up backwards look and test for a dead short across the power leads-----there is a diode just inside where the hot lead goes that will be shorted .
SD TECH
Apr 21, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra cb radio backlight inoperable
look inside at meter--two wire bulb with rubber boot slides at a angle into the meter and is easy to replace.
Apr 06, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Need to wire a high gear m75 for acobra sound tracker
It should already be wired for that radio. Its a cobra mic, on a cobra radio, its all wired for cobra. Witch is a very common mic wiring.
Nov 09, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
My cobra 29 wx nw st can recieve, but will not broadcast
Could be anything from a broken microphone wire to a bad final or regulator.
Sep 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
COBRA 29 WX NW ST
have somebody look and see if there are any bad solder joints inside the radio...
Jan 10, 2009 | Cobra 29 LTD CB Radio
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
136 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
