Question about Canon Pixma iP6000D InkJet Photo Printer
My Canon PIXMA iP6000D InkJet Photo Printer is printing in black & white only. How can I adjust it so that it will print in color? Thanks!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Check your printing preference.
You may be in print in grayscale.
Posted on Dec 31, 2010
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
Printing black pictures green
check all inks replace as required run test first check leads
Oct 03, 2009 | Canon Pixma iP6000D InkJet Photo Printer
How do i fix my canon pixma ip6000d when i switch on error code 5100 appears
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 25, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Hi, just trying to solve a problem with Canon Pixma iP6000D printer. For some reason it does not print the black ink but all the other colours??? Any help? Tks Mark
make sure that there was still black ink on your the printer.
Clean the print head if you suspect that the nozzles might be clogged.
  • Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
May 01, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Color issues
yes you can switched to hp but remember first as per your printer usage you can buy printer having big ink bank cartridge.
Good Luck!
Nov 30, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Canon pixma ip6000d
First you need to check that the printer has the same problem with a new cartridge, otherwise may be a cartridge problem. After this try doing a nozzle cleanup. You will find the option on printer properties in control panel, or opening canon software from start menu. If after this you still have the problem then you should open the printer and clean the waste ink well and printer head.
Feb 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Printer jamming when printing in color
make sure the color cart. are installed correctly
Nov 22, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Oct 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
161 people viewed this question
old marine
old marine
