Question about HP Compaq nx6310 Notebook
6120hp notebook some body has enter for my notebook to bios password now i want enter the bios how i remove bios password but i can go windows
  • 3,940 Answers
I've dealt with portable master passwords on Dell systems, but not HP systems, but I'm pretty sure the technology is the same.
To reset an lost/unknown administrative password will likely require a call/chat with HP Technical support.
At Dell, you have to prove you own the system, and after that they generate a master password to access the system. Hopefully, you can get the same kind of service from HP.
Posted on Jul 08, 2008
Reset bios password
Go to command prompt
Or
Press and hold window key and press "R" key
Type:- cmd and Enter
Type:- debug and Enter
Type:- o(not zero) space 70 space 2e and Enter
Type:- o(not zero) space 71 space ff and Enter
Type:- Q and Enter
Restart your computer and check Bios password should be removed
You can use hiren boot 15.2 software and can be easily download
May 11, 2013 | Toshiba Satellite M115-S3094 Notebook
Enter password when turned on msi notebook
There are many password options on computers.Windows PasswordDisk Encryption passwordHDD password (Set in BIOS)BIOS config password (Set in BIOS)Boot password (Set in BIOS)
If you have your boot order to boot to CD/DVD before HDD then you can download the Hiren Boot CD, burn it to disc and use one of the BIOS password wipers available.
Alternate method, some laptops will be easier than others. You can open the laptop up and remove the CMOS battery for about 30 seconds to reset all BIOS settings to defaults. The battery will look like a watch battery but about the size of a quarter. or a round disc with a couple wires coming out. Google "CMOS battery for images" Start by openingn the back panels and you may get lucky and have easy access to the battery or you may need to remove either the front or rear body completely.
Jan 26, 2013 | MSI Computers & Internet
Bios password remove
Basic input/output system, or BIOS, is an interface to start and load the operating system. Making changes to the BIOS will change the way the operating system operates. Sometimes to make changes to the BIOS, you will have to enter the BIOS password. If you have forgotten the password, you can bypass it.
1.Download and install a BIOS utility such as CmosPwd or KillCMOS (see Resources). These utilities will remove BIOS passwords provided you are in MS-DOS or Windows mode.
2.Locate the jumper switch on the laptop's motherboard. You can identify the jumper switch by CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD label. Once you have found the jumper switch, remove it and place it over the pin that is not covered.
3.Locate and remove the CMOS battery for at least 5 minutes. This will reset the BIOS password. Then enter the generic BIOS password to enter the BIOS.
I hope you find it very helpful. Thanks.
Sep 05, 2011 | Toshiba Satellite A300-0CF035 Notebook
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
I am failing to remove the Bios password in Dell Latitude D630
This should be pretty easy to do.
1. Reboot your laptop and select F2 to go into the BIOS settings. You'll need to be quick or it will boot to Windows.
2. Use the --> arrow key to move to the Security page.
3. Arrow down to the Set HDD password and press Enter
4. Enter your current password
5. Select the Enter key twice to enter no password
6. Select the F10 key to save and exit.
Dec 17, 2009 | Dell Latitude D630 PC Notebook
Forgot password and cant enter bios with out it
BIOS password is stored in c-mos battrey...A small battery in the motherboard.....if u take out the battery and put it again.....The password will b lost....and then it won't ask for bios password...
May 04, 2009 | IBM ThinkPad T43 Notebook
Password on bois
When I lost my windows password, I like to reset Windows Password with Windows Password Reset 9.0 and I think it is excellent and professional!
Once the password is removed, there is no need to type any passwords but to leave it blank, and click the user name to instantly log on Windows.
Mar 19, 2009 | Acer Aspire 5630 Notebook
Ibm t20 think pad
There is a company called pwcrack online that maybe able to help you out. If they can't help you would have to replace the motherboard which is not very econmical to do so.
Thanks
Todd
Laptop Guy
Apr 23, 2008 | IBM ThinkPad T20 2647 Notebook
Reset ecs notebook bios password
send me ur email and I'll post u software to reset bios and passwords then u can enter bios easy.or you can remove rtc battery for 5min then replace thus resetting bios.
Apr 09, 2008 | Computers & Internet
PASSWORD
IF ITS BIOS PASSWORD NEED TO BE REMOVED FROM MOTHER BOARD OF NOTEBOOK, IF WINDOWS PASSWORD YOU MAY FORMAT WITHOUT REMOVING THE PASSWORD. BUT YOU WILL LOOSE DATA FROM THE HARD DRIVE.
Feb 26, 2008 | Toshiba Satellite 2430-S256 Notebook
HP Compaq nx6310 Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
