Question about HP Photosmart C5180 All-In-One InkJet Printer
I want to print photos from my laptop onto four by six photo paper, and i loaded the photo tray with the paper, and changed the tray preference to photo tray, but it's still telling me that there's no paper.
  • 876 Answers
You also need to change the paper type in printing preferences.You will find 4x6 and 4x6 with tab in th pull down menu where it says plain paper. Be sure to position the paper as far as it will go into the printer and close the paper controls to hold it there. Also fan it well before you put it in.
Posted on Dec 31, 2010
I can't get my hp photosmart printer to print photos from my hard drive onto the photo paper. It will print the photos from the paper tray.
You have to shift the paper tray. Click on start, click on printer/faxes right click click on your printer, click on printer preferences, select photo printing borderless. This shifts your paper tray to photo paper.
Dec 20, 2010 | Computers & Internet
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
Jun 25, 2008 | HP Photosmart C7280 Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
229 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
