Several stations have no audio, some only the tv program but not commercials half of the stations work ok
  • 876 Answers
Is this a new television? Please recheck all connections and compare them to the chart that came with our television.If you do not find a problem with the connections, please write back with the make and model of your TV.
Posted on Dec 31, 2010
I have a sony trintitron model kv20fs12 that i just bought used.A few of the channels have audio only during commercials. When the show comes on it has no sound. One channel has background noise such as...
Check your TV's audio settings and make sure it's not set for SAP (second audio program). You'll probably find it's turned on. On many channels or programs you won't notice anything since the broadcast doesn't include a SAP signal. But if the signal's there, the set switches to that sound channel and you have the trouble you describe.
The problem you might run into is that you often need the original remote to control the audio settings. I don't remember for sure if your Sony model has front-panel menu control. I believe that series does, though. (The remotes included with most TV sets usually have a single button to control SAP, which is often how the settings get changed in the first place. Someone hits the button and doesn't know it.)
Hope this takes of your mystery sound! Thanks for using Fixya.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Lousy sound on 32" Sony Bravia
if you are have problems with in built speaker when the tv speakers are on, then connect on audio out hi fi
audio out. and make sure your speakers are on off.
Jan 16, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sound on my rca tv
I wonder if your problem with loud volume occurs primarily on commercial breaks, when you turn down
the sound and then, since the sound, for the program itself, is so low in volume, you have to turn it way
up again to enjoy the program?
If this is the case, and there are no other problems with the set, this may not be the set's problem, but the
fact that commercial material is broadcast at a higher volume than program material by some outlets, so
that while you are in the kitchen, during commercials, the sound of the commercial can still be heard.
Apr 18, 2009 | RCA Televison & Video
Commercials come on and volume is louder than tv shows
Volume and video levels for live broadcast, as well as satellite feeds are preset at a master control panel prior to broadcasting. TV commercials are pre-recored via satellite feeds, on seperate equipment, where audio and video levels are set manually by a technician. These manually set levels are very difficult to match, since the levels on the master control panel change. When the master control technician switches control to mark, a robot, mark loads the commercial and it is broadcasted, hence the different audio levels.
Mar 15, 2009 | Philips Televison & Video
Have a JVC42X788 model tv. TV receives signal through basic cable. On channel 29 which is the Lifetime channel the audio is in Spanish, except for the commercials which are in English. Any idea what is...
You might want to go into the audio setup or tuning setup for the tv and make sure it's on ummm, stereo, I think, but definitely make sure it's not on SAP (see if you can find SAP somewhere in the audio/tuning setup and change it). SAP stands for Secondary Audio Program.... most stations don't use this feature, but some will put out an alternate audio signal on this for whatever reason (like another language). Hope this helps!
Mar 04, 2009 | Televison & Video
Spectroniq PLTV-20NW32 volume only works on some channels
Hi lisadean767,
It is possible that without realizing, your TV is programmed to receive SAP or Second Audio Program audio. When this happens, your TV responds like this: when SAP is not being broadcast, you'll receive regular program audio. However, when the SAP audio is sent along with the regular, (English) program audio, your TV will automatically switch to the SAP channel. You'll know your TV is programmed to receive SAP because you'll hear the commercials in English and any other program in English if the SAP is not being sent.
Check and see if your tv is setup for SAP. Let me know if this helps and if I can be of further assistance, Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 22, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV sound much louder on commercials
It is Not your TV this is done by advertisers to get your attention and it works
Dec 23, 2008 | Insignia NS- 27" TV27 TV
Intermitent no sound on digital, KDL26S4000 sony bravia TV
Try going in the settings and turning off "Steady sound". Or turn the audio setting to stereo, disable surround sound.
Steady Sound
You don't have to listen to commercials at a higher volume than the normal programming. This TV has a volume equalization feature for both program and commercials to enhance your audio entertainment.
Selvol
Bravia XBR 42"
Nov 22, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture and sound don't match
You may have the second audio program (SAP) enabled.
Dec 05, 2017 | Philips Magnavox 20MC4304 20 in....
Problems with Emerson EWC27T3 27 in. TV/VCR/DVD Combo
You'll need to set your audio options to back to normal, not SAP...accordianman
Oct 12, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
