Question about D-Link Xtreme N DIR-655 Wireless Router
Windows 7. cannot access router by typing into the web browser these numbers: 192.168.0.1 get message that webpage cannot be found. router seems to be working because i can access the web as normal. router is connected to my Motorola SB5120. thanks.
    Novelist:
  • 125 Answers
I got your issue, If you want to log into 192.168.0.1 , make sure that the computer is online wired or wireless with your router, then try to open the page using http://192.168.0.1. If still its not opening the page then follow these steps,
1. Click on start--> Go to all Programs--> Accessories--> select command prompt
2. You will get a black window, which is the command prompt and you will find a small cursor blinking there you type in "ipconfig" (without cotes) and then hit enter.
3. Check what is the IP address/ IP v4 ipaddress , which must be in the range 192.168.0.x
4. Then in the next line type "ping 192.168.0.1" (without cotes) then it will give you reply 4 times and with the ping statistics Packets send=4, Received =4, lost =0.
5. Then type in the next line "start iexplore 192.168.0.1" then you will get Dlink router setup page opened.
Good Luck!
Thanks in advance!
Regards,
Prema.
Posted on Dec 31, 2010
I need to access the router
Assuming Windows 7,
click the Windows "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or the "DHCP-server").
Type that IP-address into your web-browser.
Feb 02, 2014 | D-Link AirPlus Xtreme G DWL-2000AP...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Look for the IP-address of the "gateway" (or "DHCP-server").
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
How to find lost password for access
It is not likely you will be able to recover the password if the individual who implemented it is unavailable to provide it. Your only alternative is to factory reset the device according to the manual and then put in the necessary settings required. The default username and password for this device is easily found in the users manual for the device, found here:
http://www.belkin.com/support/article/?lid=en&pid=f5d8236-4&aid=14394&scid=942
Aug 13, 2011 | Belkin F5D8236-4 Router
Lost my 10 digit network password
You will need to login to the router. go into wireless setup then security. Based on your router either it will show you the key or you will have to create a new key.
if you don't know how to access your router
via a windows based computer...
open up the command prompt or CMD usually found in programs or accessories.
type in ipconfig and press enter. it will display a IP, subnet and gateway addresses the string is something along the lines on 192.168.1.1 what ever the gateway is type the string of numbers into your web browser without the www.
Oct 15, 2010 | Computers & Internet
Cannot access a site although have put in browser, to acitvate it, have been having error page 403, gone into browser but still will not allow access to stite requested.
HTTP Error 403 is an error message which means that you are not authorized to view the web page which you are attempting to load. Usually, the HTTP error 403 - Forbidden means that access to the file/folder you are trying to open has been denied, either on intention or owing to a configuration anomaly. You could attempt using a proxy website if the access is blocked intentionally.
May 29, 2010 | Microsoft Internet Explorer 8
My itouch says its connected but wont open any webpages
Please follow the steps below to login to the router page and check the network key:
make sure that other wireless device is working fine,if it is working fine then you can try these steps
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Changed SSID(network name)and changed security
6. click on wireless setting'(under advanced)
7. click on SETUP ACCESS LIST (Turn Access Control On)it should be unchecked
then try to connect wirelessly
regards
prakash
Mar 11, 2010 | NetGear DG834G Router
Since installing a new router, it will not let us access msn yahoo, or youtube, it knocks us off within seconds, it is exactly the same router as before just a newer one, on the old one we had no problems...
It sounds like you have more than one issue going on. One possible issue with the yahoo and msn messenger could be that you have port/app filtering enabled. In order to fix this, you must go onto your router's configuration (the webpage for its settings), and go check the Port/Application & Gaming filter area to see if any ports are not permitted (since I don't know exactly what router you have, I can't tell you exactly what to go to, but I can give you a general idea of what to look for). If that is the case, simply disable the port filters, and save your settings. If that doesn't fix the problem, then make sure that use don't have parental controls, or Access policies enabled that deny you from using those applications. The youtube problem sounds like a different problem all together. It could be anything from a bad internet connection, to slow internet, to a setting on your browser preventing it from working. My suggestion for that would be to try to access other websites using your same web browser, and then try to access youtube from a different web browser. If you can access youtube from another web browser, but can access the other pages from the first web browser, your problem may be in the browser with that specific page. On the other hand, if you can access youtube, and cannot access any webpage on the first browser, there probably a problem with that browser in general. If you cannot access youtube with either, but can access other websites, then its probably not you browser.
If you still have a problem after following these steps, I would recommend contacting your ISP, or having someone come and look at your network in person.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Acess problem
Go to start and type run then type in cmd then type in the cmd box ipconfig and then look for your default gateway number.
type that number in your web browsers address line.
will look something like this but your number will be different.
111.111.1.111
Feb 06, 2010 | D-Link AirPlus DI-524 Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Blekins wireless g router- remote access trouble
You may have inadvertently configured the IP addressing by accident. If you are running Windows, open a command prompt by going to Start-Run and type cmd and click OK. A black box will appear on your screen. You need to type ipconfig, and press Enter. You will get 3 numbers. You want the result from the default gateway. Write down the IP address of the default gateway, and then enter it into your web browser. This will get you to a login prompt for the Belkin.
Please let me know if you would like further assistance with this matter. Thank you.
Mar 26, 2009 | Computers & Internet
D-Link Xtreme N  DIR-655 Wireless Router Logo
111 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
