Question about Samsung 226BW Monitor
My Moniter won't work!
I have a Samsung 226 22" Widescreen. I stepped out of the room and on my return moved my mouse to turn on the screen (a habit which we all do subconciously by now). I heard the drives start spinning and the light was still glowing on the monitor but the monitor would not start. I turned off the pc. Unplugged the monitor, plugged the monitor back in but this time had absolutely no light glowing around the switch. My monitor is now as dead as bad disco!Although sometimes I can hear a whiney high pitched sound coming from my moniter, and the blue light around the power will blink on and off, but no matter what I do it'll keep doing this. The high pitched noise is the sound that a t.v. will make when you turn it on. Oh please help me!
    Scholar:
  • 32 Answers
That high pitched sound in one way is a very good thing. It pretty much points out the source of the problem itself. That is more than likely either a blown capacitor or transformer on the power source inside the monitor. I would rule out the power inverter for the LCD backlight because the power light will not turn on either. I have found that Samsung is very good with their repairs, and if it is a somewhat recent model they should be able to get it drop ship repaired with little expense. That can be an inconvenience, and if you do decide to replace the monitor altogether, please be eco-conscious and have the old screen either donated to a goodwill organization where scavengers like me will buy it for raw parts, or to an electronics recycling center. E-Waste is becoming a very large problem and LCDs and flat screens are a hefty piece of it.
Posted on Jul 08, 2008
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
Moniter won't come on
The problem is in the power supply board often caused by one or two capacitors that open, some will show a bulge at the top making it easy to spot.
Mar 23, 2012 | Acer AL1916W 19" WideScreen LCD Monitor
I cannot expand my aol screen to fill the entire moniter. As a result the right side is off screen and cannot be rolled,deminished or canceled
Hi there, This sounds like an easy one.Try this first,put the arrow at the top of the AOL screen and press the left click button down and hold it.While your holding the button down move your mouse to the right and the AOL screen will move as well.If this won't work,right click on the desk top and choose property's or screen resolution and change it to the highest resolution you can.You must say yes soon or it will go back to the same resolution you had.You will still have to drag the AOL screen back to center.One other thing ,use file at menu to exit AOL screen.
Aug 20, 2011 | Computers & Internet
Hi! and Happy New Year! Hoping you can help me with a problem with my moniter. When it starts up it says Flatron f engine for the model type. Problem: for about 2 weeks now, at start up the moniter...
I suspect your computers power setting are turning off the monitor and not reactivating it (waking up) I would suggest attempting to change your power setting to never turn off monitor and see if that fixes the problem.
Please let me know if that works if not I can go over a few trouble shooting steps with you.
Thanks
Dustin
Jan 03, 2011 | LG Computers & Internet
I cant get past the user login screen. my arrow on my moniter isnt moving. plz help.
plug out your mouse again and plug it in, then start the computer from the start. If happens again, then the mouse may have gone faulty otherwise if the mouse is ok, it will work.
Sep 12, 2010 | Dell Computers & Internet
My computer screen is blank on computer. have logitech ex110
Did you try moving your mouse? After a period of time of inactivity the computer will go in standby mode which can be a black screen.
Sep 28, 2017 | Logitech EX110 Mouse
Window does not expand to entire moniter
right click mouse
select Graphic Properties
select Display Settings
select Display Expansion
select Full Screen (No Border)
Mar 24, 2009 | Samsung SyncMaster 205BW LCD Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
263 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
