Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Runs Fine But won't Shut Off - Troy Bilt Tb320bv Spring Assist Blower/Vac
  • 183 Answers
One of two things will keep the engine from turning off. The most likely cause is a dirty kill switch. Pop the switch out with a small knife or screwdriver, disconnect the wire leads. Clean the switch by spraying WD40 or contact cleaner into the switch and blow it out with compressed air. Check your local repair shop to see if a new switch is available. They are usually about $5.
The other possibility is an open circuit in the ignition module. If repairing the switch doesn't solve your issue, replacing the ignition module is usually too expensive to mess with. Just use the choke to kill the engine.
Posted on Dec 31, 2010
  • thebundys Dec 31, 2010
    Yep Thats What I thought, it's never the cheap fix Thanks.
  • George Kovach
    George Kovach Aug 07, 2014
    I don't see any way to simply pop the switch out. Appears the switch is attached from the inside on the tb320bv.
Scoot runs and drives fine but will not turn off by ignition
Hi, Zak you may have a faulty ignition switch for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day. Scooter won turn off
how to fix gy6 Scooter wont turn off kill switch not working Great Prank...
GY6 Scooter wont turn off kill switch not working Great Prank Keeps...
http://www.apriliaforum.com/forums/showthread.php?227549-2001-SR50-Won-t-shut-off
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 02, 2016 | Motorcycles
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
2001 ford taurus car starts fine drive it for awhile then shut it off and it wont start let it sit and it will start battery is fine
Does it crank?If you shut it off and you restart after a few minutes and it cranks but won't start or starts and runs rough the injectors are leaking and flooding the engine. Need better description
Dec 07, 2011 | 2001 Ford Taurus
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Car runs fine then all of a sudden won`t idle faster than 15 mph
i would take it in and have it checked before it leaves you stranded somewhere. theres a reason the check engine light comes on so theres something not right with your vehicle
Feb 10, 2009 | 2006 Ford Fusion
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
342 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
