Question about Samsung RS265LABP Side by Side Refrigerator
Water dispenser does not work--ice is fine - Samsung RS265LABP Side by Side Refrigerator
    Problem Solver:
  • 12 Answers
Your water dispenser has a water hose that is connected to a water facet (usually on the wall in back or on the side). The water hose goes from the facet to the refrigerator freezer. Sometimes that hose will get stopped up.
First, cut the water off at the wall. Then remove the hose from the refrigerator ice-maker. Get a small pan and place the open end of the water hose into the pan. Now, cut on the water at the wall. Does the water come out of the hose? If it does, there is no stoppage in the hose. If it does not, there is a blockage. If there is a blockage, try to find it by taking a blunt small instrument and insert it in the hose. A blunt instrument may be like a opened clothes hanger. There is also an instrument that you can get at the local hardware store that will help you. If as above there is not a blockage in the hose, you may want to check the entrance hole to the refrigerator ice-maker. There may be a water deposit that is stopping the flow of the water.
Hope this helps, Dana
Posted on Dec 31, 2010
Maybe a kink or clog in the line?
4 Suggested Answers
beamerguy740
  • 65 Answers
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Posted on Mar 29, 2010
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
imufo2
  • 3773 Answers
SOURCE: My samsung RF266 stopped running
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 22, 2011
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Samsung RS265LABP Side by Side Refrigerator Logo
96 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
