Question about Kohler - Toilet - One-piece - Santa Rosa - K3323-52
The two bolts that holds the toilet bowl down. one on each side. the whole things turn ad i cannot take it off
  • 784 Answers
A lots of the time when that happens you will need to use a grinder or a ' Dremil ' tool to cut the bolts that are holding down the toilet and get some new bolts and re-install. **** there is also a chance that if you CAN turn the bolt itself from the top that you can get the bottom of the bolt ( which is ' T ' shaped ) to turn in the right direction and get the bolt head to slip through the slots in the floor plate. since you will most likely need new bolts to re-install the toilet, go buy the new bolts at the hardware store and by looking at the bolts and looking at a floor plate at the store -- this will give you a idea of what you are trying to remove.. ( it is kinda like a puzzle ). ******
also --- sometimes you can get a hacksaw blade ( by itself -- not on handle ) to fit between the floor and toilet and cut the bolts that way,, this is kinda a pain to do, but in a pinch it sometimes works good.
I hope these ideas help you --- good luck ( ! ).
c...
Posted on Dec 31, 2010
  • 520 Answers
Try pulling up and then turning the nut. if you can not get it at all then sometimes the only choice is to use a hacksaw on it. cut under the nut but you must hold the nut so nothing moves while you cut the bolt. replacement bolts are sold at hardware stores. if the flange below is bad after you get the toilet up, they also sell repair flanges, menards, home depot
How do i remove a broken bolt which is embedded in the toilet, the bolt keeps the toilet seat lid fastened to the toilet?
There has to be either a nut and washer under the toilet, or if its reversed a bolt head with a washer under it holding it down. To remove it you can either use a hacksaw blade between the bowl and the bottom of the seat. Or use a dremel tool to slowly cut away the metal rod, etc., from the top. If using hacksaw put down some masking tape on the bowl so you don't scar up the enamel surfacr of the bowl. Work slowly and you will eventulaly cut through it.
Aug 16, 2014 | Crane Plumbing Home
Tip
How to reset your toilet
Things you'll need.
New toilet bowl bolts, wax ring, toilet flex supply line (if you don't plan on re-usings old) , crescent wrench, channel locks, plastic cup, newspaper, hack saw, towel, protective gloves (latex, vinyl).
First thing is to turn off the water supply to the toilet. Flush your toilet and hold down the lever to get as much water out of the tank as possible. Now take a plastic cup and scoop out the remaining water in bowl, throw into tub or sink.
Take your crescent wrench and un-bolt tank from floor. If bolts spin, I suggest just cutting them right below the nut, being careful not to scratch or break your toilet. Your toilet will break or crack if your put to much pressure on it, the most common spot for a crack is by the bolt holes. Dissconect supply line from tank holding cup below it to catch the water, if supply line is flex you can leave attached to shut-off valve, if rigid, remove from shut-off valve. Use towel to wipe up water.
Place newspaper out on floor. Stand over toilet facing the tank, your legs on either side of bowl, grab toilet right in front of tank on the bowl. pick straight up, your going to be hunched over while your carrying the toilet and walking like a penguin, just try to keep toilet level as you carry to newspaper.
Remove old seal from bottom of toilet and around toilet drain. Wear gloves and put spoils into plastic bag. Use screw driver to scrape any chunks up. Clean area. Remove old bolts from toilet ring and place new ones in. If toilet ring is broke, call a plumber. Place new wax ring on toilet ring. Make sure bolts are pointing straight up. Get toilet above bolts and lower slowly guiding bolts through toilet holes. After toilet is on, push with light steady pressure straight down to help wax ring spread out even and make new seal. If toilet is leaning towards wall as you push then compensate to have it lower level as possible. Never use a cold wax ring, have it at room temperature. After its lowered sit on toilet for a minute.
Remove any wax that has oozed out and place nuts on bolts, with washers going on first. Hand tighten both sides, then take crescent wrench and tighten down slowly alternating sides, a couple turns on one side then a couple on the other making the toilet set level and ensuring a good seal.
Do not over tighten As it gets harder to turn nut, take your index and thumb and pinch the end of the wrench. Hold with enough force to just hold the wrench, tighten until your fingers slip off. That's the best way I can describe how to tighten bolts safely with out damaging your toilet, if there is a leak you may need to tighten a bit more, use your best judgment. Use hack saw to cut-off excess of bolt,
Attach your supply line and turn water back on slowly. Test for leaks, if no leaks your good.
Do not caulk around your toilet: all that does is turn a leak into a disaster by keeping it hidden from you, Eventually your sub floor will rot and you will have a huge repair bill.
Other Tips:
http://www.fixya.com/support/r5204270-slow_shower_drain_fix
http://www.fixya.com/support/r5197305-stop_water_sweat_solder_water_line
http://www.fixya.com/support/r5245506-leaking_shut_off_valve_hard_close_shut 5e9c605.gif
on Jul 06, 2010 | Plumbing
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Tank to bowl leaks
Turn water supply line of to toilet. Flush and hold handle down to drain water from tank. Take lid of tank off and use a towel to soak up the rest of the water inside tank. Remove nuts on bottom of Tank bolts. Lift off and lay down on its side. Remove the rubber or sponge type gasket that is on bottom of the tank that covers the nut from standpipe assembly. Buy new gasket and install back on bottom of tank over Nut for standpipe. Put tank back on toilet bowl. Install bolts and tighten. reconnect water line and turn on.
Aug 25, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
When the toilet is flushed water comes out from under the toilet bowl
The wax ring has gone bad. If the toilet moves when you set on it you might try snugging down the bowl bolts on both sides but be very careful not to go to tight you will brake the bowl.
If you decide to try to fix this your self with you buy a new wax ring buy the one with the horn in it they seal better.
Jan 31, 2011 | Home
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
Leaks when cleaning the bowl. Bowl moves a bit. Plumber was afraid to tighten bolts too much for fear of breaking bowl. How tight?
Leaks at the floor or the tank where it meets the base behind the seat?
Generally tight enough to sinch it so as not to leak.
If the whole unit moves on the floor the wax ring may need to be replaced. If the tank leaks be sure the bolts are tightened evenly with new gaskets sealing them inside the tank. Tighten the nuts evenly until it stops moving freely and the leak should stop.
Dec 17, 2009 | Toto Aquia II Dual Flush Toilet
How do I install a gerber 21-375 Toilet? It came with no instructions.
The Gerber Ultra Flush Back Outlet toilet, that uses 1.1 Gallons of water to flush?
Just like any common toilet. Install the tank to the bowl of the toilet, set the toilet, install the flush mechanism in the tank, attach the supply line.
1.MAKE SURE you put the two plastic U-shaped spacers on the back of the bowl!
2.Install the round rubber gasket in-between the tank and the bowl.
3.Set the tank down on the bowl. Make sure you have the round gaskets that go up under the bolt heads, then insert the two bolts into the tank, and through the bowl. NOT installing these will cause a leak!
Tighten these bolts down, until the nuts are JUST touching the tank. (There is a flat washer that goes under each nut)
DO NOT tighten one bolt all the way, then tighten the other bolt!!
These bolts MUST be tightened evenly. Tighten one turn on one bolt, then go to the other bolt.
DO NOT overtighten, or you will break the bowl, and/or the tank!
Make sure your toilet flange on the sewer pipe is in good repair, and clean, from the old beeswax ring. It can be messy, even using gloves. Use a flat painters stick to help remove the old wax ring. Scrape off into a old can. The wax thin residue on the floor and flange is fine.
Set the new wax ring in place, remove the plastic liner that comes with the ring. DO NOT leave that thin plastic liner! It's just to install that wax ring!
Install the bolts that hold the bowl to the floor, or reuse the old bolts if they are in good repair.
Tighten EVENLY, and don't overtighten! You can crack the bowl.
Now install the toilet mechanism in the tank.
Here is a 1 Page, Tank to Bowl Installation Guide from Gerber. It is a PDF file. Let it download ALL the way before looking at it.
http://gerberonline.com/fileLib/Toilets%20Ultra%20Flush%20IS.pdf
Should this direct link not work for you, here is the page it came from,
http://www.gerberonline.com/Catalog.aspx?categoryID=2204&itemID=3514
It's on the right side -> Installation Instruction (PDF)
Jul 02, 2009 | Gerber Blades Gerber Ultra Flush White ADA...
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Leaking toilet
check the seal between the tank and the toilet.tighten it as necessary. (not to tight! you will crack the ceramic). Mkae sure the tank is square to the toilet.
also the water inlet connector.
Nov 24, 2008 | Saniflo 013/003/005 Sanibest Toilet with...
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
108 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
