Question about Whirlpool WFW8400T
My wfw8400tw03 leaks from under the detergant draw when it fills
SOURCE: he2 leaking from detergent dispensor
We had the same problem, It was a pair of sock stuck behind the seal in the drum blocking the water inlet to the drum. Like others we managed to get our fingers between the metal of the drum and the rubber seal near the detergent dispensor to remove the sock.
Posted on Mar 01, 2008
  • 135 Answers
SOURCE: Water leaking out slightly from
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Posted on Jun 21, 2008
  • 105 Answers
SOURCE: water leaks around detergent drawer
Best off to call a reputable service company such as Sears.
Posted on Feb 06, 2010
Jahn27
  • 1554 Answers
SOURCE: Miele 435-plus washing machine Problem: water
There's a hose or tube that goes from the dispenser cavity to the tub that is likely clogged. Small clothing can be siphoned into the hose or tube and block the water path causing it to leak out to the dispenser drawer. Locate the hose/tube port in the tub where the blockage may be located, if not, you have to remove the front panel fully access and take the hose/tube out for inspection.
Disconnect power then remove the screws attaching the top panel to the rear of the machine and slide it rearward and off. Remove the dispenser drawer then the screws securing the console to the machine cabinet. Lift the console off then remove the screws securing the front panel to the cabinet. Slightly lean the front panel forward and disconnect the door lock and switch assembly wire harness. Remove the front panel and set it it aside. The hose/tube can now be fully accessed for inspection. Reassemble the machine in reverse order of the disassembly steps.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need further advice regarding the issue stated herein.
Posted on Feb 25, 2011
kelvin971
  • 6 Answers
SOURCE: My whirlpool wfs1273bd leaks water from under the
This product has to be my most hated product in the entire house. We have had nothing but issues with this piece of junk. 2 days ago water and foam started pouring out the soap dispenser and across the laundry floor. Not to anyones surprise as this machine has been a dud for 2 years.
So i finally got to looking at this tonight, and was blown away by a) what tiny little thing caused it, and b) the simplicity of it (did it in 1/2 hour) when I thought this was going to be a all night job with 1000 parts across the floor.
How its done:
  1. Remove the power and water pressure from the washer
  2. Remove the 3 screws at the rear of the machine on the top plastic trim (that hold the top of the machine on.
  3. Slide top panel of the machine towards the back, it will become dislodged from the front control panel.
  4. Remove the soap dispenser tray
  5. Undo the 3 screws in the soap dispenser frame, that join the front panel to the water mixing chamber
  6. Undo the two screw on top of the front control panel that are exposed from removing the top panel of the machine
  7. There are two clips, either side of the control panel inside the machine that hold the front panel on. I could undo the one opposite to the soap drawer, but I couldn't get the other, so jiggle the control sideways (left and right) and applied a pulling pressure and it came free. Rest the control panel on top of the drum, I didn't undo any cables, they seem to stretch over the front on top of the machine.
  8. Remove the bottom sump panel - apply a inward pressure on the top of the sides of the panel, and pull outwards. It will hinge away with the hinge on the bottom of the machine.
  9. Undo the screws that attach the entire front panel including door (two on top far sides, and 3 across the bottom.
  10. Pull the entire front panel forwards gently, and the lining between the front panel and drum will stretch out about 2 inches.
  11. Reach in around the front panel and you can see the black tube run down from the soap mixing box, into the main drum.
  12. Gently yank/pull the black tube away from the main drum, it has a rubber flange on the other side that stops it coming out, but it will come through.
  13. See if you can clear the blockage in the tube (if there is), you may need a pair of pliers to remove the black tube from the bottom of the soap box.
  14. Assembly is the reverse, ensure that you get a good seal on the tube back into the drum. I did this by forcing the flange back into the drum, further than it was originally, and slowly and gently pull it back out, until the drum lip pops into the ring on the rubber tube.
Notes: Dont lose the screws in the soap box down the tube, its a absolutely huge job to open the drum. Put a towel ontop of the floor drain in your laundry, its a icky job to retrieve that!
Good luck, and never buy a Whirlpool machine again!8_27_2012_9_31_19_am.jpg8_27_2012_9_32_25_am.jpg8_27_2012_9_33_06_am.jpg8_27_2012_9_33_59_am.jpg8_27_2012_9_34_42_am.jpg8_27_2012_9_36_14_am.jpg8_27_2012_9_36_34_am.jpg
Posted on Aug 27, 2012
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
WATER IS LEAKING FROM THE DETERGENT DISPENSER DURING FILLING CYCLE
you will have to remove thee draw and clean the water jets they get clogged up with old soap and lime
Apr 17, 2012 | Samsung WF218AN Front Load Washer
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
Water leaking from deyergant compartment
Make sure these isn't any foreign objects in the tube that leads into the drum from the detergent tray.
Remove the top of the unit. 2 screws in the back. Top left and top right and slide the top off. Look under the tray and locate the tube and feel around. You may have to remove the tube to get a better look.
Dec 24, 2009 | Samsung WF218AN Front Load Washer
Whilpool front end loader leaks water after done filling
theres a hole in gasket (bellows),,,,now also check your detergent draw if water pressure is to high it will splash over and come down inside of cabnit...
Dec 24, 2008 | Whirlpool AWM5125/1 Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Jun 21, 2008 | Whirlpool Washing Machines
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8400T Logo
Dan Webster
Dan Webster
Sal De
