What is machine level language - Computers & Internet
    Scholar:
  • 59 Answers
Hi, Machine languages are the only language that are understood by the computers.While easily understood by the computers machine languages are almost impossible for humans to use because they consist entirely numbers.Machine level languages are in binary codes 1, 0 which only computers can understand normally.
Advantage
The only advantage is that program of machine language run very fast because no translation program is required for the CPU.
Disadvantages
  1. It is very difficult to program in machine language. The programmer has to know details of hardware to write program.
  2. The programmer has to remember a lot of codes to write a program which results in program errors.
  3. It is difficult to debug the program.
Posted on Dec 31, 2010
Hotpoint aquarius washing machine why has h 20 come up on my machine
http://www.hotpointservice.co.uk/help-and-advice/error-codes
F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked. F11 - No hot fill. The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked. F12 - No mixed fill. It is likely that the water is not turned on at the taps. F13 - Check the water supply, inlet valve and hot and cold hose connections. F14 - A fault with the water heating has occurred* F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked. F16 - Extremely high water level. Disconnect or turn off the water supply and ensure that the water level does not rise any more* F17 - Door not closed properly. Close door firmly at the 3 o'clock position. F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing* F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persist, book an engineer. F40 - Water below protection level during a heat step* F41 - Water level detect sequence incorrect* F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language)* - See more at: http://www.hotpointservice.co.uk/help-and-advice/error-codes/#sthash.w5Uocmoi.dpuf
Sep 08, 2014 | Washing Machines
We put in the application CD and tried to to insert the langage cds but it is not recognizing any of the language cds.
In order for the language CD to be recognized, you must first open the Rosetta Stone Launcher application. Within this application, there is a button that looks like a bulleted list, which, when clicked, will display a menu of options. Among these options is 'Add a Language Level'. Place the language cd in the cd drive, then click the 'Add a Language Level' option. Select the language level from the list that appears and click the 'install' or 'add' button. After a short wait, the language will be installed.
Mar 17, 2011 | Rosetta Stone Spanish (Latin American) -...
Hi, I'm using Rosetta Stone 3 online through a school license. I keep getting a 'loading next screen' box popping up, but it gets stuck at three quarters loaded, and refuses to go any further! Any ideas on...
Do you have the issue with other levels or languages as well? Maybe you can try removing and then adding the languages again, and see if that helps. As a last resort, you can also try reinstalling Rosetta Stone if this occurs with all languages and levels you own.
Mar 12, 2011 | Rosetta Stone Version 3 Swedish Level 1 2...
Change language back to english?
For the m240 Sandisk gives next information, how to change the language on m200 series players:
NOTE: All the steps start from the Main menu.
1. Settings Option can be accessed by going to the 4th item on the list.
2. Language is the 5th option after Settings.
Manual for the m200 series:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Page 27 (=page26) of the manual shows how to go to the top level, main menu. Page 26 (=page 25) gives the table for top level menus.
How to change the language for (other) Sansa players, see next link:
http://kb.sandisk.com/app/answers/detail/a_id/7
Nov 21, 2009 | SanDisk Sansa m240 MP3 Player
What is java programming language?
http://en.wikipedia.org/wiki/Java_(programming_language)
In order to understand the difference between high-level programming languages and lower level languages you might have to have a deeper knowledge of computers than you currently have, although I can try to the best of my ability to explain it simply.
Lower level programming languages are more directly related to the actual machine language that the computer ends up reading in the end. Higher level programming languages are less representative of the actual machine code, and as a result may require either a more advanced compiler or may require being compiled several times. Generally higher-level programming languages are easier for the user to write in than lower-level languages.
Nov 11, 2009 | Sun Computers & Internet
Garmin 265 W won't speak street names
Below is the procedures for setting the languages...
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
Regards
Richard
Apr 26, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 780
please click.
You should be good now
Regards
Richard.
Jan 23, 2009 | Garmin nuvi 780 GPS
What is a compiler and ite story
A compiler takes code that you have writin, and 'compiles' it into machine language code ex.10010011, a language that your computer can understand and execute.
Jan 15, 2009 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
