Question about Air Tools & Compressors
Hydralic pump losing hyralic fluid - Air Tools & Compressors
  • 297 Answers
Hello, please explain your problem to me.
Matt
Posted on Dec 31, 2010
Electric convertible top does not completely retract on 1997 328i
check hydraulic fluid level in the hydralic motor pump behind left side trim panel in the trunk.look on side or end of the motor pump assembly.look for screw type check plug. first place rags under the check plug to catch fluid spill unscrew the check plug fluid level should be 1/4 inch bottom of check plug hole if low you need add correct level fluid. then screw in check plug back in place.to bleed air out hydralic system you need helper to hold switch while you raise and lower the top slowly by hand raise and lower top several times to remove air out hydralic system. see if your convertible top will open and close all the way.
Oct 17, 2013 | 1997 BMW 318
211 cat excavator hydrolics working slow
When did you change the hydralic fluid last? How about the hydralic fluid filter or filters? Is it cold where you are, if so you should be using winter rated hydralic fluid. Also, you may have to turn up the engine speed to get the hydralic pump to put out more volume at a greater pressure.
Jan 13, 2013 | Televison & Video
Mini cooper convertible top won't go up
do you hear hydralic motor if not use test light while operating control switch up and down position, you need a helper for this procedure.if power is at switch, see if power at hydralic motor while helper work the control switch, if no power at motor hook test light to good ground if no power at hydralic motor check fuse.if power at hydralic motor and you hear no sound hydralic motor bad.if power going to control switch and not to hydralic motor either control switch bad or you have broke loose wire at switch going to motor.if all electrical system okay and when you work the up switch and hear hydralic motor running your hydralic fluid level low reason why convertible top not going up.check fluid level at the side of the motor and pump you should see screw type check plug.you should have see through side reservoir fluid level should be between min and max marks.if fluid is low check for leaks at the pump hoses and hydralic cylinders.
Nov 27, 2011 | Mini Cooper Cars & Trucks
2007 MItsubishi eclipse spyder Convertible top stuck open
convertible top could be low on hydralic fluid if you have trouble getting top open or closed.check hydralic fluid hydralic pump located in trunk area look for a screw type check plug on side or end of motor pump assembly.give me more detail about back window panel stuck up.
Nov 13, 2011 | Cars & Trucks
Convertible top not going up.
LISTEN FOR HYDRALIC PUMP MOTOR OPERATION IN THE TRUNK AREA..IF YES YOU HEAR HYDRALIC PUMP MOTOR RUNNING MAKING A NOISE.CHECK HYDRALIC PUMP FLUID LEVEL BY REMOVING THE SCREW TYPE CHECK PLUG.PLACE RAGS UNDER THE CHECK PLUG.AND UNSCREW REMOVE THE CHECK PLUG. FLUID SHOULD BE 1/4 INCH BELOW THE CHECK PLUG HOLE.IF FLUID IS LOW ADD FLUID UNTIL FLUID LEVEL 1/4 INCH FROM THE PLUG HOLE.IF HYDRALIC FLUID WAS WAY LOW YOU NEED TO BLEED AIR OUT OF THE SYSTEM.MAKE SURE FLUID LEVEL CORRECT.START ENGINE AND TRY RAISING AND LOWER THE CONVERTIBLE TOP USING THE SWITCH.IF TOO MUCH AIR GOT IN SYSTEM.HAVE A HELPER WORK UP AND DOWN CONTROL SWITCH WHILE YOU MANUAL OPEN CLOSE CONVERTIBLE TOP BY HANDS BLEEDING AIR OUT OF SYSTEM.KEEP EYE ON HYDRALIC FLUID LEVEL WHILE BLEEDING THE SYSTEM..LOWER THE TOP AND TURN OFF ENGINE. BEFORE OPENING THE HYDRALIC PUMP FLUID CHECK PLUG BECAUSE FLUID WILL SPRAY EVERY WHERE..IF HYDRALIC PUMP CHECK OUT OKAY AND YOU DO NOT HEAR NO HYDRALIC PUMP NOISE.POWER IS GOING TO HYDRALIC PUMP.EITHER HYDRALIC PUMP MOTOR FAULTY OR FAULTY HYDRALIC PUMP RELAY BEST TO LET MERCEDES BENZ DEALERSHIP CHECK IT OUT...
Apr 30, 2011 | 2005 Mercedes-Benz Mercedes Benz SLK350
Top only works half way
CHECK THE HYDRALIC MOTOR PUMP FLUID LEVEL IN THE TRUNK AREA.REMOVE THE SCREW TYPE PLUG ON THE SIDE OR END OF HYDRALIC MOTOR ASSEMBLY.PLACE RAGS UNDER THE CHECK PLUG TO CATCH FLUID.FLUID LEVEL SHOULD BE 1/4 INCH BOTTOM OF THE CHECK PLUG HOLE.
Mar 25, 2011 | 1996 Saab 900
Power steering is hard and eps light is on
Check fluid in the system, check for the serrvo pump action , if not the system must be overhauled as there is less assistance from the pump to give the hydralic thrust.
Possible failure of pump, pump belt or hydralics.
Sep 19, 2010 | 1997 Honda Accord
I Bought a Mustang about a month ago and im having problems with the Convertable roof Every time i lower the roof it wont come back up it took me five people to raise it. Once i went to the dealership they...
YOU HAVE TO CALL FORD DEALERSHIP PART DEPARTMENT THEY WILL GIVE YOU THE PRICE.HEY I WOULD CHECK HYDRALIC PUMP FLUID LEVEL FIRST PUMP IN THE TRUNK AREA..IF FLUID LOW ADD HYDRALIC FLUID BLEED AIR OUT SYSTEM.AND SPRAY PENETRATING LUBRICANT ON ALL FRAMEWORK JOINTS TO PREVENT BINDING.
Jul 03, 2010 | Cars & Trucks
John Deere 310 A Hydralic problems
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Air Tools & Compressors Logo
16 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
