Question about Sony Playstation 3 (PS3) Console
The ps3 will turn on but nothing will load and when I any system options the system freezes
    Master:
  • 508 Answers
You need to reflow your gpu and cpu with a heat gun found on ebay pretty cheap also called a hot air gun.
Posted on Dec 31, 2010
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
I get a screen but it freezes.
ps3 turns on then little color squares appear then it freezez. what can i do
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
Wont load!
Try going in to the playstation diagnostic menu. This is accessible as follows:
Make sure you have the controller charger cable plugged in and your controller plugged in before you start. While the PS3 is off press and hold the power button, the PS3 will start, beep 3 times and then turn off again. Once it's switched off take your finger off the power button for a second or two then put it back on, listening out for two beeps, then remove it. On the screen it will ask you to plug your controller in and press the PS button, do so and you'll be presented with 6 options.
The first one you want to try is restore file system, this will check your PS3 for any errors on the hard drive, and correct them if they can. This may take a little while but let it run through and see if it works.
If not then move on to the next option, but BACK UP YOUR DATA BEFORE DOING SO, the next step will wipe your PS3 clean! Repeat the process above until you get to the menu and then select "Rebuild database".
Try these two first and let me know if it helps! :)
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doesnt work
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on Home Screen?
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
Feb 15, 2009 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Freezing
you have dust build up brother. take a can of dust off and while the system is running pulse some air throught the front vents. you should see gobs of brown dust flying out the back....you system is freezing because its overheating(is that an oxymoron?) good luck!
Aug 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
