Question about Home
The jets on my aker swirlbath tub do not work. what do you think the problem is?
  • 784 Answers
Could be a few things ---
1. it could be the on/off switch.
2. it could be a loose wire.
3. it could be a bad motor.
4. it could be a blown fuse or a bad breaker at the panel.
c...
Posted on Dec 31, 2010
  • jadamjr Feb 28, 2011
    The air activation tube could have come off of the button or the pump activation plug by the motor. I am dealing with the same issue now. My problem is I found the hose fell off by my arms are not long enough to connect it back onto the button.
I have an AKER Swirlbath by Delta and (2) of the jets do not work how or whom can I get to repair/fix the problems
try forcing water down the other jets one at a time to see if this clears the blockage, use a hose or shower hose
Nov 12, 2014 | Baby Gear
The jets on my aker Swirlbath are coming on by themselves in the middle of the night. What is the remedy for this problem?
Some tubs with air jets have a sensor that detects water in the piping and cycles the air pump to blow out the water in the air jets. Make sure the faucet is not dripping as the water leaking into the tub could be causing the pump cycling problem.
Hope this helps.
Bob
Aug 11, 2014 | Home
Aker swirlbath manual
Any manuals for the Aker by Maax bathtubs will be available directly from Maax, who makes the Aker brand bathtubs.
Feb 22, 2014 | Home
Find air switch for aker swirlbath
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. You need part # TBS-310
US Parts Center
Feb 14, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
US Parts Center
Jan 11, 2014 | Home
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
I have a 14 year old Aker whirlpool tub. During bathroom remodeling, I found a leak where the pipe comes out of the jet. I could not repair it. Are the jets available yet? I found two numbers on the...
Jet bodies match only the jet trim that goes with them. These are a set and are not interchangeable with other models or brands of jet. Each Bath Part in unique in subtle ways only.
In order to find the correct jet body you need to match up the face of the jet trim to what is shown online. Once you know that brand of jet trim we can find you the correct jet body.
I would invite you to search our site at US Parts Center and see if you can find the jet face that you have.
Once you do we will be able to match up the correct jet body for you.
Rod
US Parts Center
888-521-6183
Jan 15, 2013 | Whirlpool Royal A-909 Bathtub
Where can I buy just the brass trim on the jet for my whirlpool tub (aker)?
The trim for any brand whirlpool (w/p) tub must be ordered from that specific tub manufacturer. They will need to know exactly what your particular model is.
The model of your w/p tub, and serial number, is most often, but not always, located on the motor end of your unit but not on the motor itself. Access to this end of the tub, if installed to code, should get you the information you need, otherwise you are out of options'
Jun 03, 2010 | Whirlpool Royal A-909 Bathtub
Home Logo
1,193 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
