Question about Nokia E52 Smartphone
Can not turn E53 on. will not charge, even with the charger plugged in.
  • 425 Answers
First try if your charger is working.
next, try to remove your battery and check if it is not dead by using a multi-testers and place it again if it is ok.
if still not charging then most probably that you have a software problem. have your phone reformat at to your nearest service center. you you will be needing a special gadget to do this.
Posted on Dec 31, 2010
  • Nokia Master
  • 554 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
sir, rate my answers too.
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
I just received my Thunderbolt Magnum Charger that I had ordered from Harbor Freight Tools. I plugged it into my 2012 Nissan Rogue to try it out and it turned on my car's radio. I assumed this was not a...
This charger is a maintenance charger and will not have enough power to charge a dead battery. It is used to trickle charge a battery to keep it charged and to off set any parasitic drain.
Feb 17, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
Cruz tablet
The charging light should remain on as long as the charger is plugged in and charging I suggest you try to troubkeshoot your charger as it might be faulty.
Sep 23, 2013 | Velocity Micro Cruz T410 4GB 10"...
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
Notebook won't turn on or charge (new charger and new battery)
The New battery will not be charged yet, I wouldn't of thought, until you plug it in and charge it.
your problem is with the connector inside the Pc, that the charger connects to,
This has come lose and is now failing,
$150/$200 to repair the connection.
Regards
Richard.
Apr 22, 2009 | Sony VAIO XG39K PC Notebook
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Nokia E52 Smartphone Logo
243 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
