Question about Curtis Audio Players & Recorders
My curtis mp2013uk will not charge on the usb cable
I have the same problem with 2 of them (my kids are well annoyed). They WERE working fine!
Posted on Sep 25, 2014
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
Curtis mp2013uk can't play downloaded tunes
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.
FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Curtis Televison & Video
HOW TO PUT MUSIC ON IT
You will need a USB cable that came with the device. First load the songs you want into a folder on your Computer (PC ) . Then connect the Curtis to the PC using the cable. Right click on the song folder and select copy. Then go to My computer and right click on the Curtis tab and select paste. The song folder will be transferred to the Curtis.
May 01, 2011 | Curtis MPS1015 MP3 Player
I have an Curtis MPK4099UK MP3 Player. It says to charge it I need to install setup.exe from the CD. After I done that I restarted my computer then I put My MP3 Player on charge,(with the on switch) It...
I had the same problem but have now resolved as follows. Turn the top switch to on and connect via USB port. Picture should come on the mp3 player indicating it is connected. For some reason unknown to me in order to charge you need to turn the MP3 player on - but this is impossible if there is no charge. What you need to do now is leave the MP3 player connected like this overnight - it will then have gained enough charge in the morning so that when you then disconnect the MP3 player from the USB lead you are able to actually turn it on. PLEASE NOTE this is not turning on by the switch at the top. What you do it press and hold the circle/dash symbol i.e. at the bottom of the white keypad bit on the front of the MP3 player. As you then let go it comes on. Let it finish turning itself on, then reconnect to the USB lead and leave over night to get a full charge. Good Luck
Sep 25, 2010 | Curtis MPK2066 MP3 Player
Need code for Cable remote to work tv
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 15, 2010 | Curtis KCR2610 7 in. Portable Television
Missing CD-ROM & cables for Curtis Digital Camera Model# DCD5159
Well it appears that Curtis has discontinued all support for this camera. You might be able to obtain a USB connector that fits the camera online. Most use the standard/micro USB connector. As far as drivers if Curtis does not have it on their site then they might be tough to find. If you are using Vista the it might recoqnize the camera and install drivers automatically. If the camera has removable memory card you could remove the card after taking the pictures and put in the SD port of the computer and transfer the pictures onto it.
Sep 19, 2009 | Cameras
I can not charge my player via usb, the battery ran down and now it will not charge.
Try charging with switched ON position. AAlso batteries may require replacement.
Jul 15, 2009 | Curtis MPK2066 MP3 Player
Curtis MP3,Model MPS1015 Input cable
Replacement USB cable for MPS1015 can be purchased for $7.00 from Curtis International Ltd. Please mail a certified check or money order (payable to Curtis International Ltd) to 315 Attwell Drive, Etobicoke, Ontario M9W 5C1, ATTN: Customer Service Department. Make sure to include your name, complete mailing address, phone number with area code, model number of the unit and part required.
Jul 07, 2008 | Audio Players & Recorders
Codes
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
Feb 21, 2008 | Televison & Video
Curtis mp3 player
I think you are going to have to connect the Player up to your PC via it's USB cable and then possibly repartition and reformat.. Do you have the, any? software that came with ya player installed on ya PC? If so often all "Utilities" to do this are included. Here is a link to the Curtis web troubleshooting I am sure ya will find help there too. http://www.curtisint.com/support/troubleShooting.asp
Aug 12, 2007 | Curtis SMP228 MP3 Player
578 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
