Question about Michael Kors Chronograph Stainless Steel Bracelet Watch for Women
I am trying to shorten the watch strap of my Michael Kors stainless steel watch for women but cannot get the pins out by simply pressing on them...any suggestions?
escapement
  • 2334 Answers
SOURCE: trying to shorten stainless steel watch strap
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 27, 2009
SOURCE: invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Posted on Jun 16, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
watchmacher
  • 302 Answers
SOURCE: changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Posted on Oct 08, 2012
  • 10 Answers
SOURCE: Where ca I buy A new stainless steel strap and
As long as it's not a strap exclusive to your watch, you should be able to take it to any jeweler who sells watches or a watch selling kiosk in a mall. I wouldn't take it to a store like Wal-Mart, just because they have no requirements for their employee's to know a crown from a clasp, for them to work in the jewelry area.
Posted on Jul 02, 2010
WHAT SIZE BATTERY IS IN THE MICHAEL KORS WATCH
OMG, why does it take s much to answer and who wrote the first answer? Perhaps she works for some repair woman? The answer to this question for Michael Kors Acrylic Womens Watch MK5248 is a 364 battery. It took longer for me to find the answer to this question than it did to replace the battery on my gf's watch. Here's a tip go to a hardware store or Amazon.com and by it for much cheaper than Walmart or like stores. you van get a 10 pack for about $5 on Amazon. Remove the screws over a white pillow case so that when/if they fall as you remove them you can easily see them. Took less than 5 mins to remove and replace the battery. Enjoy
Oct 17, 2014 | Michael Kors Watches
How do I change the watch strap?
There are typically small pins that hold the band together. There is a special tool to use on metal watches that can be bought
Jul 29, 2014 | Klaus Kobec Womens Couture Leather Watch...
How to resize Michael kors mk5216
Arrows on the inside of the band shows the direction that the pins should be pushed out.
Feb 16, 2013 | Michael Kors Womens Acrylic Brown Dial...
Changing battery in Michael Kors watch
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
Ladies quartz watch stem winder knob lost lost how to remove from another to fix it?
mcdevito75 here, Best bet, look for a small watch repair shop in your area for another knob. As long as the stem is in place you just need the winding knob.
May 23, 2011 | Michael Kors MK5166womenGold Tone...
How do I set the date on Michael Kors chronograph watch? I thought it was set, but after February the date is 3 days behind.
I just set mine.....the stem has to be barely pulled out, there are two stem setting but the first is very easy to miss. Once you barely have it out turn and you will see the date change.
Mar 14, 2011 | Michael Kors MICHAEL Chronograph Bracelet...
Stainless steel band won't snap into my watch
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Invicta pro diver strap length
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Michael Kors Chronograph Stainless Steel Bracelet Watch for Women Logo
8,418 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
colinat108
deton8 von Splosion
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
