Question about Black & Decker String Trimmer Cordless 12" 18V
Hedge trimmer jammed - Black & Decker String Trimmer Cordless 12" 18V
  • tmwag Jul 28, 2008
    I hit the chain-link fence, and the thing quit. But, there is still power going to it - i can hear and feel it it wanting to go. Took apart the two-piece cover, but could not see anything obvious.
ctf1800
  • 4402 Answers
SOURCE: i have a black and decker hedge trimmer g25?
just take it to a electronics service shop that can resolder it for you
Posted on Aug 05, 2008
  • 313 Answers
SOURCE: (hedge trimmer blades do not
you know what the problem is. it the motor magnetic ring that is
broken. it also called stationary parts of the motor.
Posted on Aug 29, 2008
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
vincob
  • 718 Answers
SOURCE: I have an 8104 type
Did you ever oil the cutters since you have owned it? Try this spray some PB Blaster on the cutters let it soak and then try running it. If you can't find that stuff just try some motor oil, pour it on let it soak and give it a whirl. Good Luck...
Posted on Aug 24, 2011
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
Broken won't move
Check the teeth for something jamed. Has it set up for many years, maybe rusted bar. Does the motor run? If so maybe a cam gear broken or jam. Does the teeth on the bar move when removed from unit? Or does the motor run when bar removed? To many question to ask need more info.
Jul 04, 2015 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Stihl hedge trimmer jammed on a stick now the blade is tight and won't move
take it in for repair as the cams on the blade ends are damaged /bent or the teeth of the blades are bent.
May 23, 2015 | Garden
Craftsman cordless trimmer jammed
tools that become jammed from turning 1st need to be found out 4 cause of jam , and jam removed then a ck of the electicial motor for any faults inside of it need be looked at , if none found, a relube and reassembly of tool needs to be done
some common causes of tool jamming are : foreign object stuck in a tight fitting spot, lack of lubrication and tool is too dry to move , bent moving item on tool ,an hard jolt has been given to tool and some part of moving assembly has bent and become jammed tight, like dropping tool this would be a hard jolt
Jan 06, 2014 | Craftsman C3 19.2 Volt Cordless Hedge...
I have an 8104 type 7 black and decker hedge trimmer. It freezes up durning the cutting or just squeezing the trigger. Makes a loud buzzing noise. Almost like it is jammed and there is nothing jammed in...
Aug 24, 2011 | Black & Decker Decker Ht018 18" 26...
B&D electric Hedge trimmer I was cutting bushes and hit the chain-link fence. Now, the trimmer just hums. Can it be fixed?
Yes it can but you need to find what jammed. I would check for a bent shaft or a wrapped cable. Good luck
Apr 26, 2010 | Garden
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Black & Decker String Trimmer Cordless 12" 18V Logo
111 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
