Question about Kenmore HE2 Plus Front Load Washer
CODE F-21 NOT SPINNING THE WATER OUT when it comes to the rinse cycle . IT MAKES A CLICK SOUND AND STOPS . THEN IT SHOWS CODE F-21
    President:
  • 1,554 Answers
The machine is not spinning the water out because there's a problem with the drain system as the error code indicates. Either the drain hose is clogged or kinked, the pump filter is blocked, the pump impeller is blocked or damaged or the pump itself is not working at all. The click sound may due to a blocked pump impeller.
Disconnect power and the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Posted on Dec 31, 2010
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
My washing machine stops working when it goes into the rinse cycle. It just makes a humming sound coming from the dial.
does it pump out the water first if not suspect lid switch..also ck to be sure cold water is getting through valve ckd cold inlet screen in fill valve most washers use a cold only rinse
Jul 09, 2008 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
578 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
