Question about Singer Sewing Machines
How do I replace the handwheel belt on a Singer futura 920? I can't figure out how to get enough access to the belt to replace it.
SOURCE: Singer futura 920 sewing machine
This problem is related to the tension of the threads, try adjusting the upper thread tension to see if it improves.
Posted on Feb 15, 2008
yalmer
  • 552 Answers
SOURCE: clutch actuating spring fell out of handwheel
http://www.singerco.com/accessories/manuals.htmlSinger
There is a manual and some helps here.
Posted on Mar 13, 2008
SOURCE: Singer Futura 900
Complete instructions for filling the bobbin and threading the Singer Futura 900 can be found here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_900_futura_threading.htm
Posted on May 07, 2008
  • 5 Answers
SOURCE: replace a motor belt for sewing machine
The top tension is dependent not just on the tension dial, but also on the little disks that you go through to thread the machine. If it is not threaded correctly, you will get bunching underneath. Sometimes I just have to rethread the machine-- when you get to the disks- hold the thread taut and push it through the disks before going up to the arm part. Here is a threading picture I found- but it doesn't point out the disks too much. Once the machine is stitching nicely, then the tension dial can be used to flatten out the stitches.
Posted on Mar 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for singer futura 2000
SINGERCO.COM
It is available at the link above for $15 - there is no longer a free download.
THanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 20, 2009
Who uses a Singer 6235? How would you compare it to the Futura II 920? Anyone know the original retail price of either machine?
THE SINGER 6235 ARE BOTH GOOD. I'VE LOOKED AT THE FUTURA AND BELIEVE IT IS NEWER THAN THE 6235. THE FUTURA WILL GIVE MORE CHOICES OF STITCHES. EITHER ONE WILL BE A GOOD PURCHASE. EITHER ONE WILL BE HEAVY SO YOU KNOW THERE IS A LOT OF METAL FOR LONG LIFE. THE ORIGINAL PRICE IS HARD TO FIND OUT. IF YOU WANT TO KNOW TODAYS SELLING PRICE YOU CAN CHECK EBAY FOR A GOOD INDICATOR. THE PRICE AT THE TIME YOU ARE SPEAKING ABOUT MIGHT HAVE BEEN AROUND $200-$400.
Nov 19, 2014 | Singer Sewing Machines
How do I replace the drive belt on a Singer Athena 2000?
Generally, the hand wheels have a screw at the center that is covered by a white disk. You use a flat bladed screwdriver to "pop" the disk off, and the screw is underneath. If there is no screw, then it's a "force fit" and you remove it by squeezing the wheel together and "rocking" it off.
Oct 18, 2014 | Singer Sewing Machines
Thread keeps bunching on the bottom of the material when I sew. Have a Singer Futura 920
Generally bunching underneath is related to the top tension. Check your tensions - you might have to fiddle around a bit to get it right
Feb 28, 2012 | Singer Sewing Machines
I dumped everything off computer and still cant get futura ce100 to open did what singer said several times still won't open and machine is on. Please help running vista.
Make sure your USB cable is plugged into one of the USB ports on the BACK of your computer. The front ports or a USB hub doesn't have enough power to run the USB cable for the machine. Singer doesn't have enough computer knowledge to figure this out-this was finally solved for me by a PC expert at work after I went nuts for a few months! Hope this helps!
Jan 13, 2011 | Singer CE-100 Futura Computerized Sewing...
I have lost the Access Key from my CD to the Futura Software. The software is loaded on my system but is asking for the key. (Singer Quantum Futura CE 200)
You will have to contact Singer customer service.
They have a website where you can look at FAQ and Futuras to see if this has been addressed before sending the question.
Mar 27, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
I have this machine for more than 30 yrs-- when this happens, the top thread is not pulled through the little disks correctly when you go up before getting to the arm. Here is a threading diagram
Feb 15, 2008 | Sewing Machines
Sewing Machines Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
