Question about MumboJumbo 7 Wonders of the Ancient World for DS
7 wonders II come up with a range check error
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
I have a jennair model sce30600wc, it was showing a f7 error code. if iI unplugged the oven it would usually work. Now the display does not illuminate but the oven works. DOes the keypad need replacing or...
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 14, 2011 | Jenn-Air SCE30600 Slide-In Electric...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
After a power outage my oven is unable to work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(((((((((
Jun 06, 2010 | KitchenAid Architect II KEBK206SSS...
Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Mar 02, 2010 | Amana AGDS902 Gas Kitchen Range
Default code P1451 Land Rover Discovery II
The code P1451 on a Land Rover is "Leakage Detection Module Motor power stage error Drive cycle A:Signal out of range - above maximum". This is an OBD-II diagnostic system code. As far as I know, a 1995 Land Rover Discovery does not use a OBD-II system. Is it possible that this rover is a later model year
Oct 11, 2009 | 1995 Land Rover Discovery
Projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Jan 20, 2009 | BenQ PB6100 Multimedia Projector
MumboJumbo 7 Wonders of the Ancient World for DS Logo
748 people viewed this question
Top MumboJumbo Video Game Consoles & Games Experts
ray gallant
Tom Chichester
Are you a MumboJumbo Video Game Console and Game Expert? Answer questions, earn points and help others
