Question about Amana ARS266ZBS Side by Side Refrigerator
My frig pulls just 2.5 amps, runs all the time except during defrost. Freezer gets no lower than 15 degrees F. Suction pressure is maybe 10 psig. Suction line into compressor stays frosted up. Suggestions ?
  • Anonymous Mar 26, 2014
    suction pressure will not drop lower than 25psi
    Sergeant:
  • 183 Answers
It may be overcharged. Check the Pressure/Temperature chart of the refrigerant that you are using and correct accordingly.
Posted on Dec 31, 2010
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Recently had the ice maker repaired / replaced and shortly after, the section between the freezer and refrigerator had standing water. Also, in both pull out crispers in the frig have water in them. The...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Freezer is -13 &frig is 56 degrees
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Monogram ZICS360NR Bottom Freezer...
Our Amana frig temperature is approximately 60 degrees with the lower freezer under 32 degrees. The unit is running constant. Any repair solutions would be appreciated.
Check and see if the fan is running in the freezer. If not may be bad or frozen. If is running check and see if there is any frost in the freezer if the fan is in the back then check the back wall of the freezer. If yes the it is not defrosting . Thaw it out for 24 hours and it will work for a week or so but it will need either a defrost timer, heater or thermostat.
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
This is a new fridge and the element located in the lower freezer behind the pull out drawer is red hot with water dripping on it? we had the same problem with our old fridge and this is why we replaced...
the element you see in the back of the freezer compartment is the defrost heater. your frig will defrost 2-3 times every 24 hours for 15-30 minutes. when its in a defrost cycle the element will get hot and melt the frost that has built up on the cooling coils from normal operation. the melted frost will then drip down ..some will hit the heater and sizzle,most will drip onto a tray and go down a small drain into a pan under the frig and then evaporate out.. Also ,it doesnt defrost at the same time each day., it is based on how much the frig runs and the electronic control will figure out when it it time to initiate a defrost..the red glow and the sizzling is normal and only lasts a short time....
Mar 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Amana ARS266ZBS Side by Side Refrigerator Logo
222 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
