Question about Flotec Plumbing
Hi, I have a Flotec FP4108 3/4 hp shallow well jet pump which I use in a 2 bedroom apt. The pump is quiet only when using the washing machine but quiet noisy otherwise. Is there anything that can be done about that?
5 Suggested Answers
r_dawg
  • 50 Answers
SOURCE: I have a flotec jet pump for a shallow well. It
If this is a new problem that has just started
The GFI mite be bad or the motor mite be going bad Need to check the amp draw of the motor this will tell you witch is the problem
Posted on Jul 12, 2009
  • 151 Answers
SOURCE: I have a Flotec shallow well pump. The motor is
could be bad bearings,obstruction in impeller,low voltage,failing capacitor.
Posted on Dec 24, 2009
  • 119 Answers
SOURCE: where do i get parts for flotec 3/4 shallow jet
online or from the manufacture.
Posted on Apr 19, 2010
  • 520 Answers
SOURCE: Flotec shallow well jet pump
got any more info?
Posted on Oct 03, 2010
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
Hi there my flotec 1/2 hp shallow well jet pump has a crack in the casing how can i repair this until i can get a new pump?
If it is on the pressure side about the only repair would be to get it welded. If on the suction side you MIGHT be able to "V" it out slightly and use JB Weld or maybe even Bondo... Tose will NOT work on the pressure side however.
Dec 13, 2010 | Flotec Corrosion Resistant Shallow Well...
Flotec 1/2 hp motor only buzzes when circuit breaker is turned on...
hi i had the same problem last week mine turned out to be two things 1 the filter was blocked and 2 the capasitor was shot and i had to change it if this the case never downgrade but y can always upgrade hope this helps
Nov 14, 2009 | Flotec Corrosion Resistant Shallow Well...
I got a brand new Flotec 2 HP Jet pump and installed it but now it is overheating and smoke is coming out. Why is this happening and how can I fix it?
WAS YOUR NEW PUMP DUAL VOLTAGE? AS IN 115VOLT OR 220VOLT. IS IT WIRED FOR THE CORRECT VOLTAGE? NEED MORE INFO IF THIS DOESNT FIX. HOPE THIS HELPS. JODY
Aug 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
55 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
