Question about Dryers
Need to replace blower fan on amana alg643raw dryer. Fan just spins on motor shaft when shaft isnt turning.How do I get it off
  • 425 Answers
There is a set screw or a pin at the blower fan side that is locked to the shaft. try to unscrew it usually using a small allen key. if it is removed then you can now pull out the fan.
Posted on Dec 31, 2010
GE duet electric dryer. Airflow is erratic/sputtery.
M Pandora,
The squirrel cage fan would not have any bearings. When you turned the fan and you said it did not turn freely, you may have also been turning the entire drum because you would have been turning the motor shaft which then turns the belt and pulley. Not necessarily a bad thing. When you shut the dryer off, does it make a rattling noise as it comes to a stop? If it does, you may have a stripped hub in the center of your fan, and it will need to be replaced. Another way you can tell if it might be stripped is have someone watch the drum while you turn the fan, and if the drum does not move while you are spinning the fan, the hub is stripped. Those fans have a flat spot in the hub and they can get rounded out and that can cause the symptoms that you are describing. Hope this helps!
Feb 24, 2015 | GE Dryers
I can't get the motor shaft off the fan
From inside dryer hold blower wheel with wrench that fits the squre part of blower wheel turn motor shaft clockwise should loosen the blower wheel............
Jun 21, 2014 | Whirlpool LER5636P Electric Dryer
Whirlpool duet 2004 model heats but wont spin
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Also check outvideos for other style dryers. If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
Oct 21, 2012 | Dryers
For past 6 months dryer has been making a noise while drying and when I turn it off sounds like it is still spinning for a second. Now dryer is making a squealing noise as well and not drying the clothes...
Sounds like the blower wheel (fan ) is loose on the motor shaft.... that is the spinning you are hearing...
but the fan/blower is not running full speed so it is not moving enough air...
heatman101
Jan 18, 2011 | GE DBXR463EDWW Electric Dryer
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
Dryer turn on but would not spin
When the dryer will not spin the most common cause is a broken dryer belt.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 14, 2009 | Kenmore 63942 Dryer
GE Dryer model DBXR463EDIWW
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
Dec 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryer guide wheel was noisy and I opened the dryer up and found the wheel and stud badly scored. Fixed that and put machine back together and now the motor is very noisy and the machine shuts off...
you need to check the blower fan. the motor has a "D" shaped shaft. over time the blower wears, the motor will spin but the blower does not. the air flow stops and the drier over heats. replace the blower and it should be fine.
Nov 08, 2008 | Dryers
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
125 people viewed this question
Top Dryers Experts
