VIZIO L37 HDTV
SOUN AND VIDIO OK MY TV SCREEN IS BLUE WHEN I TURN ON WHAT BOAR NEEDS REPLACE
Daewoo37in(dlt37g1) freeview will not store saying no signal but freeview will install on other equipment using same imput
Posted on Jul 08, 2008
  • sheila822 Jul 08, 2008
    can u help have sky and a dvd recorder with built in freeview and hard drive these work fine from same signal but daewoo will not load freeview ?
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Problem with audio and vidio
Is this a problem only with the cable box or also with oother sources as well?
Feb 03, 2008 | Pioneer PDP-6100HD 61 in. Plasma...
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
My sanyo 42 inch plasma has a blue screen, i can hear the sound on the tv but screen remains blue. can u help please
Be sure your channel settings are correct and that you have proper orientation of the hook up cables. See if your remote has a video-mute if so turn it off...a video-mute will produce a blue or black screen. To be sure its not the tuner that's enter the menu screen if you can see the menu then the tuner is ok this means the down-stream video is functioning. Be sure to have all your input devices set to the correct output ports. If all check good and still blue screen then the logic section is not processing video codecs and needs servicing.
Oct 18, 2010 | Sanyo 42 in. LCD TV
Tv turns off in 3 min with buzzing sound
CK next to FBT flyback transfomer your hori output transistor ther is a Blue capacitor 2K volts look to see if it is bad.
Jun 23, 2009 | Panasonic PT-51HX41 51" Rear Projection...
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
No vidio audio ok
Normally the symptom, audio/no video is the DMD. The light needs to be changed. Contact RCA at 866-465-7157 for a servicer in your area.
Jun 02, 2007 | RCA HD61LPW164 61" Rear Projection HDTV
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
