Question about APC Smart-UPS 750XL (SUA750XLI) UPS System
I have a Smart-ups 750 XL. Had a power black out that lasted two days. It was unplugged during that time but may have been left on and run dead. My wife plugged the ups back in to charge for a couple hours today and then booted up her computer off it. Only the “on battery” light is lit on the center two columns. The alarm is sounding and the charge indicator light has gone from 3 lights to 2 to 1. Following the manuals instructions for “circuit breaker tripped” I pulled all the plugs out of the ups and pushed in the circuit breaker to reset it. This had no effect. The outlet is good and the “site wiring light” is not on. The system is only about 10 months old. There is no load on the ups now and it is plugged into the outlet. One charging light blinks for about a minute and then it shuts off. Is it dead? Thanks.
  • 98 Answers
  • 152 Answers
SOURCE: APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
Posted on May 27, 2009
  • 1187 Answers
SOURCE: Have brand new APC 900 UPS and when plugged in,
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Posted on Sep 19, 2009
  • 7 Answers
SOURCE: New batteries in Smart UPS 700 only lasts 2 minutes at 30% load
If you blistered your older batteries a good chance your inverter is going or will go bad. The heat alone can do damage to your components. Time to replace the unit and remember next time not to wait so long to replace your batteries. Replacement of batteries every three to approaching four years is a good idea.
Posted on Oct 22, 2009
  • 15 Answers
SOURCE: "On Battery" Alarm Sounds when Power Available.
if this comes sometimes and goes, this means that the power to ups is sometimes deviating from the specific ups input range, hence the ups is rejecting it. mesure the input voltagesand frequency with a multimeter and check whether they match the specified ones in the ups manual. aslo with some ups there are switches that you use to set the input voltages or number of phases in the ups input. check the manual to see whetther your ups has such.
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: smart ups 750-replaced battery because the battery
This could be a malfunction in the charging circuit
Posted on Jul 22, 2010
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
Why won't my PC power-up?
Firstly you should not unplug your computer for long times. Inside is a battery to keep the BIOS alive. When you unplug it, it flattens the battery and if left unplugged for a long time, it kills it. This means that the BIOS now starts in default mode, which can lead to many problems because all the custom BIOS settings are now lost forever or until you or someone else change them.
Change the battery on the motherboard and try again.
The reason why the LED was flashing then stops, is that the battery has a small charge enough to be stable. Now that your BIOS battery is dead, you will never be able to charge that battery again, so replace it.
Sep 01, 2014 | Watches
2 red blinking lights on control
Hi. Why do you have two different sized batteries? When you charge them, they will not charge up evenly. You say it ran for two days, did you charge it each night or after the two days running? Batteries last the best if they are charged overnight after each days running. The two flashing lights might be a fault code. Can you tell us what controller is in the machine, we can look up the fault codes. Why was the left hand motor rebuilt? In power chairs and mobility scooters the motors develope a build up of carbon dust and copper bust from the brushes and commutator. This build-up causes a leakage of power from the wiring in the motor to the frame of the motor. If this happens it is possible to get a short developing between the two motors, which causes the controller to go into a fault mode.Good luck. Neil.
May 26, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
I set up my wireless yesterday and the notebook said the battery was charged so I unplugged it. When I woke up this morning the notebook was completely dead - nothing happenned when I pressed the power...
Plug it back in. This is usually an indication that something in the notebook was running all night and drained the battery.
Perhaps the computer did not go to sleep or hibernate.
Charge it up and use it during the day to see how long the battery lasts.
Nov 12, 2009 | HP G60-120US Laptop
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Power surge
Unplug it then plug it back in and it should power up
Oct 01, 2008 | Philips DVDR3575H/37
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
APC Smart-UPS 750XL (SUA750XLI) UPS System Logo
188 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
