Question about Canon CanoScan 8400F Flatbed Scanner
My Canon 8400F scanner suddenly will not work. I get a messge that says Code 2, 178, 0 and something about a Twain data error.
SOURCE: Canon Scanner - Twain Pilot
QUICK ANSWER: use the original USB cable that came with the scanner.
LONG EXPLANATION:
Using Vista (32 bit version) and a Canon N670U scanner with the new drivers installed from the CanonUSA website. This driver is works for Canon scanners: LiDE 20, LiDE 30, N670U, N676U and N1240U, found at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6625
Canon says it doesn't support Vista 64 bit version. I couldn't get the scanner to work and kept getting the TWAIN error also, despite uninstalling / reinstalling the driver. Finally, decided to disconnect my 3rd party 16 foot USB cable and use the original cable. I swear, it WORKED! I can't explain why, but it did. Perhaps there is increased resistance, hence reduced power going to the scanner by using longer/different USB cable? Anyhow, it worked...go figure. If you have the 64 bit version of Vista, I guess it won't work(?).
Posted on Apr 15, 2008
SOURCE: twain error
Try using the original USB cable that came with the scanner. I swear it worked for me, even though it doesn't make sense (although I suppose there is increased resistance, thus less power going to the scanner by using a longer and/or different USB cable than the one included). Give it a try.
  • 5 Answers
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Well I had a code 15 error with mine LIDE 20. Apparently the scanner needs a certain amount of power to run off the USB port. So I changed the USB port and problem fixed
Posted on Jul 16, 2008
SOURCE: Canon 8400f suddenly will not allow neg scan option
just had the same problem, check the connection going into the top part of the scanner at the back and restart which ever program your using... got mine sorted
Posted on May 22, 2009
  • 1335 Answers
SOURCE: how do i install TWAIN drive
Go to
http://www.usa.canon.com/consumer/controller?act=ConsumerHomePageAct
put in your model number and you will find the correct driver for your scanner.
Please make sure to rate this solution. Thanks.
Posted on Jun 09, 2009
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
I get an error code 2,178,0 when i try ot scan
First, make certain that the flatbed scanner lid is securely shut.
Second, unplug the power and USB cables from the rear of the scanner.
Third, deposit the Canon 8400F scanner in the nearest garbage receptacle where it belongs.
Hope this helps.
Sep 28, 2009 | Canon CanoScan 8400F Flatbed Scanner
May 20, 2009 | Canon CanoScan 8400F Flatbed Scanner
Twain Error
You will most likely find that the FAU (what the hell is FAU?!) cable that connects the lift-up lid to the lower part of the scanner has at least one of the eight wires within it fractured. This cable was made far too rigid to cope with the multiple number of times that you will be opening and closing the lid and it's a poor do from Canon that they allowed this to get through to production. I tried to obtain a replacement cable from the UK Canon service agents but was told, as expected, that it couldn't supply it. If you're a dab hand with small wires and a soldering iron, it's quite possible to make a repair and save a bit more of the world's resources from going in the dustbin and then buying another equally poorly made, expensive piece of ****, from China.
Dec 25, 2008 | Canon CanoScan 8400F Film Scanner
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Code2,178,0
This is caused by a faulty FAU cable. One, or more, of the eight wires within this cable has fractured and unless you are handy with fine wires and a soldering iron, it's off to the scanner shop, I'm afraid.
Aug 02, 2008 | Canon CanoScan 8400F Film Scanner
Error message
Scanner sensor is defective,,,you need a new scanner.
Dec 02, 2007 | Canon CanoScan 8400F Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
374 people viewed this question
old marine
old marine
