Question about Panasonic Televison & Video
I have a still picture no movement, but still hear the sound....
  • 927 Answers
Good Day;
Try unplugging the TV & cable/sat box from wall for at least 4-5 minutes, reset/reboot, plug all back into a/c again.
99.5 % of the time the problem you are experiencing is the signl source, be it cable sat or phone.
Good luck, BIG Irish.
Posted on Jul 08, 2008
How can I assure that the power supply unit PSU is defective?
You only need a PSU board if the back light inverters are combined with it. Otherwise look for the inverter board. To be sure it's defective, when the picture goes off shine a flashlight on the screen to see if you can spot movement from the program on the screen. If you can see movement then the inverter board needs replacing. If you can't see any movement then the T-Con board is bad. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Element Electronics FLX3711B 37 in. LCD TV
The screen went black can still hear the sound but no picture
Test the backlight first.
1. Play something that should have a bright fast moving picture. 2. Put you face really close to the screen to see if you "sort of" see the picture.
If you see movement, that means the backlight is out. $$$
Jul 15, 2011 | Vizio L32 32 in. LCD HDTV
Just don't know how this hooks up and works please help?
There are two components to your monitor - the sound sensor and the movement sensor.
The movement sensor is a pad that is placed underneath the crib mattress on a solid surface - if you just have springs supporting the mattress, you may need to buy a piece of plywood to place underneath the mattress. The pad is connected by a cable to the movement sensor port on the sound monitor. The other connection on the sound monitor is the power. So, position the sensor pad under the crib mattress, then plug it into the sound monitor and connect the listening unit to a power source.
You have two listening units. Just plug them in and set them to the same channel (A or B) as your sound monitor. You'll hear what's going on in the nursery, and if the movement sensor doesn't sense movement for 30 seconds, it'll chirp. If it still doesn't sense movement for another 10 seconds, an alarm will sound.
Feb 27, 2011 | Graco Angelcare Movement Sensor With Sound...
How do I use the Anglecare Deluxe Movement sensor moniter without the movement sensor? I would like to be able to hear the audio even if the baby is not sleeping on the pad but is in the room. Thanks.
mine has a switch on the back of the base unit with three options. one of which being sound only. another being sound and movement, and the third being tic off.
Oct 19, 2010 | Angelcare Deluxe Movement Sensor & Sound...
I`m driving an audi a6 1997 model(166 000 k`s). sometimes when i accelerate quickly i hear a bang, i dont what it is. secondlyone of my front and rear wheels when ever i turn especially in the morning i...
Sounds like either a motor mount is out or got play in the drivetrain. pop the hood and while in park push and pull the car to see how much movement you get with the engine. if it is a motor mount youll see alot of movement if it is tight and still hear a bang it is in the drivetrain.
IE.... axles/transmission.
Jul 19, 2010 | 1997 Audi A6
Sound and picture movement are out of sinc. sound basically doesnt match up with mouth movement
There should be an option in one of the menus called lipsync or something similar. This allows you to adjust the sound and picture sync.
Apr 01, 2010 | LG LH-E9674 Theater System
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
We can see and hear, but the other party can only hear.
This is a new problem, as we have had the camera for 6 months, but suddenly, we can see and hear the connection, but the other party can only hear us. However, when I push the snap shot button I see the picture taken and the camera has the "on" light to the left (facing the... Read more
May 26, 2009 | Logitech QuickCam Communicate Deluxe...
Sounds don't align with lip movement
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Jun 15, 2007 | Westinghouse SK-26H240S Television
AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix 4600 Digital Camera
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
