Question about SVP FS1000 Film Scanner
I just bought a SVP FS1880. The 35MM film strip will not feed into the scanner. It starts to feed properly then seems to jam before even one frame gets to the scanning window but will release the film with no difficulties. What could be the problem and how do I prevent it from happening in the future?
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
Mac compatible driver
Repost in the proper place for a possible answer
This is vehicles only
Jul 24, 2013 | 2002 Ford SVT Focus
I just bought a svp ps9000. Not knowing it was window based. Can I get it to work on my Mac?
As far as I can see this Scanner is not compatible with the Mac so I doubt you will be able to find the software you require. Sorry.
If you have just bought it take it back to the shop in the pristine condition and ask for your money back.
Sep 04, 2011 | SVP PS9700 Film Scanner
I have recently purchased the SVP Digital Film/Slide Scanner for the purpose of scanning slides and my initial response to the product is very favorable. I have however found that loading the slides into...
FixYa provides help and advice to people's problems and we are not affiliated with any companies.
You are best solution in this case is to contact the supplier of the fiim scanner or the SVP company.
Oct 02, 2010 | SVP PS9700 Film Scanner
Nikon Super Coolscan 5000 ED
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
No error message displayed when film jams
Take it into nikon specialty shop for a service.
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
SVP FS1000 Film Scanner Logo
254 people viewed this question
Top SVP Office Equipment & Supplies Experts
Jay Plesset
Are you a SVP Office Equipment and Supply Expert? Answer questions, earn points and help others
