Question about Garden
Mounting of nylon cutting head where is the hole in the head case to insert the hex head wrench? P8 of instruction manual.
  • 1 more comment
  • jematson Dec 31, 2010
    makita model RST210
    makita RST210
  • jematson Jan 01, 2011
    The Brand is Makita Model No. RST 210
  • 43,501 Answers
It will be on the very bottom on the head... you may have to pop off the cover or insert to find the hole...
heatman101
Posted on Jan 01, 2011
  • 2,926 Answers
What is the make and model of the trimmer? There are many types, and a make and model will help.
Posted on Dec 31, 2010
  • GetMeOttaHere Dec 31, 2010
    The hole is located under the bump feed cover.
Replace flywheel seal garbage disposal
follow this steps and fix it. God bless you
  1. Look for a six-sided (hex) hole at the center of the bottom of the disposer.
  2. If you find such a hex hole, look for a hex wrench, usually stored in a pouch on or near the disposer. If you don't find one there or have one in your toolbox, you will need to purchase one. Don't use a screwdriver or other tool because it can damage the hex hole.
  3. To free the flywheel, insert the hex wrench in the hex hole and rotate it in a circle in both directions.
Nov 23, 2013 | Home
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
How do you check the transfer case fluid level
  • Locate the fill plug in the center of the transfer case facing the rear. The fill plug is a hex head bolt.
  • Remove the fill plug and check the fluid level. Insert the short end of an L-shaped Allen wrench into the hole. Spin the Allen wrench slightly and remove it. Some fluid should be present on the tip if the unit is full.
  • Attach a screw-on hand pump to a bottle of Mopar ATF+4 type 9602 automatic transmission fluid. Insert the other end of the tubing for the hand pump into the fill plug hole on the transfer case.
  • Pump fluid into the transfer case until the fluid is flush with the bottom of the hole. A small bead of fluid will drip out of the hole when the case is full.
  • Reinstall the fill plug and torque it to between 15 and 25 foot-pounds of torque. Hand-tightening the plug and turning it 1/2-half turn further with a socket wrench is equivalent to 20 foot-pounds of torque if you do not have a torque wrench available.
  • Mar 01, 2011 | 2002 Jeep Liberty
    Is it possible to get the rear head off of the engine without having to remove the engine from the frame? I cant even seem to get the valve cover bolts out due to lack of clearance. Is there a trick to...
    Yes, you can remove either or both heads if we're talking about any Harley other than the V-Rod. You're talking about the rocker box cover bolts that use a 3/16 Allen wrench or hex key. Depending on the model of the bike, some models have a hole drilled in the frame to get the rearmost bolt on the left side out. Remove the seat to see if there is a hole. The other bolts can be gotten out using a cut off hex key or Jim's sells some special tools to remove them with.
    I made my own out of piece of flat steel stock, drilled a hole in it, and pressed a hex key though the hole. Grind the hex key flat on one side of the steel stock and grind the length on the other side to the depth of the hole in the bolt. Don't get the hex key hot when grinding. Cool it in water to maintain the tempering.
    Good luck
    Steve
    Aug 16, 2010 | Harley Davidson FXR Super Glide...
    How do you replace ball joints
    Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
    Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
    Step 3 Chock the rear wheels and apply the parking brake.
    Step 4 Remove the wheel lugs and the wheel assembly.
    Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
    Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
    Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
    Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
    Step 9 Pull the control arm from the stabilizer bar.
    Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
    Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
    Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
    Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
    Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
    Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
    Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
    Step 7 Lower the vehicle and finish tightening the wheel lugs.
    Step 8
    Remove the chocks from the rear wheels.
    Aug 08, 2010 | 1998 Ford Escort
    Valve cover tighten: '07 Sporster/883/low
    the size should be 3/16 inch. Now, the problem may be a clearance problem causing you to be unable to get the wrench into the hex head bolts of the upper rocker box cover. I cut a piece of the 3/16" hex key about a half inch long, drilled a hole in a piece of thin flat steel and pressed the piece of hex key into the hole. The wrench is then only about 3/8" thick allowing me to get the wrench into the bolts.
    Mar 22, 2010 | 2006 Harley Davidson XL 1200 L Sporster...
    Loose mounting brackets on JBL Control 23 Speakers
    Remove the JBL badge on the front grill, insert the supplied hex wrench and turn counter-clockwise until it's loose enough to adjust the speaker, the turn the hex wrench clockwise to tighten it. If you don't have the hex wrench, you can use a long allen wrench.
    http://www.jblpro.com/catalog/support/getfile.aspx?doctype=3&docid=1372
    Oct 24, 2009 | JBL Control 23 Speaker
    No Allen Wrench in my possession fits these holes
    Yes, there are tools called "Allen" wrenches. They come in sets.
    Mar 13, 2009 | Sony VAIO Digital Studio PCV-RZ22G PC...
    Timing belt
    use a pipe mounting plate and insert long bolts through the plate and the drive pulley. use a pipe wrench to fix the rotation against the car body. then use a 19 mm hex socket to break the mounting bolt loose. may require a large handle 1/2 inch socket wrench as the mounting torque is about 100 foot pounds. reverse the pipe wrench when tighting the crankshaft bolt.
    Jun 15, 2008 | 1989 Toyota Camry
    Dewalt dc920 repair instructions chuck
    To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
    Instructions for removing a keyed chuck
    Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
    1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
    2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
    There is no way to stop the motor from turning.
    It may require several attempts to loosen the chuck
    Instructions for removing a keyless chuck
    1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
    Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
    Garden Logo
    150 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
