Question about GE MiniCam Pro HO98656 Webcam
I can't get the webcam to work at all. I get Filter Graph error, can't connect to device...... I am running vist basic. Did all the up dates and driver stuff but no good. Is this webcam compatible with Vista?
  • Anonymous Jan 01, 2011
    Thanks. I will give it a try and let you know.
When ever i try to record a video on facebook it will record but it says audio is not being recorded...also when i try to record videos just on the web cam it freezes. any suggestions?
Make sure your webcam mic is set as the default mic on your computer - this is especially important if you have a laptop also with a built-in mic
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
The freezing problem could be for a variety of reasons - internet connection - lack of memory etc.
Ensure you have Microsoft DirectX installed and its up to date
If you installed from a CD your Logitech software itself may need updating
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to download Microsoft DirectX 9 or later to support your webcam
Procedure
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
You can also download and run this webcam diagnostic software - dont worry too much about the first alert - I always get that.
Reboot your webcam software by unplugging the cam for a couple of seconds before running the diagnostic utility
Aug 09, 2010 | Logitech Quickcam E3500 Webcam
I purchace a logitec webcam c120 and connected to the system. vidio is ok. but microphone not woking. already microphone is there in the c120 webcam? what i will do.
Try setting the webcam mic as default
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 08, 2010 | Logitech Webcam
Does this webcam have a speaker in it for video chat?
Check by running through these settings
Plug in the webcam
TEST SPEAKERS
Restart computer
Aug 08, 2010 | HP EW192AA Webcam
I have bought a Gigaware webcam 25-157 and it doesn't work for skype. Could you please provide an assistance in order to get this webacam work with skype. Thank you
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic
Plug in the webcam
TEST SPEAKERS
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Aug 08, 2010 | Radio Shack VGA PC Camera Webcam
I have installed Logitech Webcam C300 and I cannot select the Logitech Mic. I have reloaded the driver and restarted several times. Help please
You do not say what your operating system or computer system is
Here is a basic set -up for laptop ( with mic ) and webcam ( with mic ) and Vista OS
TEST SPEAKERS
Restart computer
Configure webcam to your chat program
If you have an earlier OS you may have to access your hardware from the Control Panel.
Jun 09, 2010 | Mri WebCam
Microphone Error Using Skpe with MS LifeCam 5000
Try this
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO SKYPE
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Jan 14, 2010 | Microsoft LifeCam VX-3000 Web Camera
The microphone will NOT work. It will work with skype but not with windows live messenger. Or by itself for that matter.. I need help!!!
Mic setup - Vista
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 14, 2009 | Microsoft LifeCam NX-6000 Webcam
I have the same problem
MIC SET -UP VISTA
TEST SPEAKERS
Re-start Computer.
CONFIGURE TO MSN
Webcam Connected
Open MSN
Aug 13, 2009 | HP VGA Webcam
I can see and hear my contact but they cannot hear me I have tested all the audio and microphone tests and they check out fine
MIC SET-UP :- VISTA
TEST SPEAKERS
Re-start Computer.
CONFIGURE TO MSN
Webcam Connected
Open MSN
Aug 13, 2009 | Microsoft LifeCam VX-3000 Web Camera
GE MiniCam Pro HO98656 Webcam Logo
27 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
