Question about Oreck Vacuums
How do you check to see if you need to replace the belt on a Orick Commerical XLPRO14T Vaccum.
  • 784 Answers
You can tip the vacume on it's side and turn it on and if the roller/sweeper is turning then the belt is good -- but if it is not turning then the belt is broke and needs to be replaced.
also at the same time as you replace the belt -- remove and clean the filter so the vacume is restored to normal operation.
c...
Posted on Dec 31, 2010
Install instructions orick power cord upright
You can find the assembly and wiring diagrams on this site to help you. Please check the correct model number as you have not provided this.
Oreck Upright Vacuum Parts
Aug 30, 2014 | Oreck Orek Upright Vacuum Cleaner -...
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Jan 18, 2014 | Riccar 8650/8625 s Vacuum
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
How do i replace the belt foe whirlwind vaccum
Remove 4 screws on top and top plate will lift up exposing the belt and roller. Make sure you remove hair and other debris before replacing.
Jul 15, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Belt keeps coming off.
The dowel that the belt attaches to should have a slight "V" in it. This prevents the belt from slipping off. Check that, if it isn't there than you may need to replace the dowel. I own a Bissell and every 6-8 months replace the belts anyway as preventative maintenance is my philosophy.
May 10, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Oreck vacuum cleaner stop working; earlier it was off-on while in
Check that the main plug socket isn't coming off from under the handle.
Jan 10, 2009 | Oreck XL2600 Vacuum
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vacuums Logo
340 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
