Question about Verbatim VER95327 USB Hard Drive
I have a Verbatim ac320gb USB Hard Drive. i try to format it in windows and had it say exceeded the hub power and how i have 0 bits on it. i try to reformat it and say 289 gb but windows can not format it. need help
    Brigadier General:
  • 10,406 Answers
Each USB port passes a limited amount of wattage.
The "formatting" is a "high-wattage" operation.
Try connecting to a different desktop computer, hopefully with more wattage per USB port.
Note that 289 * 1024 * 1024 * 1024 is equal to 320 * 1000 * 1000 * 1000
So, '289' (base-2) is equal to '320' (base-10).
Posted on Dec 31, 2010
My Verbatim AC320GB 320GB USB 2.0 2.5" External Hard Drive has all of my content from my old PC, now that I want to edit its content on my macbook, I am unable to. help!
It depends on which format the drive is using. If it's FAT-32 you can immediately read and write from it with your Mac. However, if the drive is formatted as NTFS you'll need a third party driver or software in order to write to the drive. Your Mac can read from but not write to NTFS.
Your should be able to read the drive.
Source: reading PC hard drive on my Mac Mac Forums Discussions for Apple Products...
Jan 24, 2015 | Verbatim AC320GB 320GB USB 2.0 2.5 foot...
WINDOWS CAN NOT READ MY HARD DRIVE, HOW DO I FORMAT?
Do you hear the drive spinning when power is supplied?
Any clicking or other sounds after power on?
Did you try different usb ports or cables to the computer?
When the computer doesn't see the drive it is usually a sign that there is an interface problem, cable or cord, power supply, etc.
Dec 23, 2014 | Verbatim 53021 500GB Store n Go USB 3.0...
The usb drive doesnot open windows need to format
We need a bit more information here. Was this a new usb ? If so you may simply need to format it in windows (a quick format would do using FAT32). If this is an usb with data on it was it used by a windows or linux os ? If windows was it NTFS?
Jun 04, 2014 | Verbatim STORE-N-GO (95312) 8 GB Hard...
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
My verbatim model#53018 1TB does not respond after it is connected to my PC
Go to the Disk management service and check if the drive shows up there. The route will depend on your OS. In Windows 7, click Start > Control Panel > System and Security. Go down to the Administrative Tools and click Create and format hard drive partitions.
Look at the lower half of the window and scroll down to see all identified disks. If your external drive is listed, something got corrupted in the NTFS or FAT record. Use a third-party drive repair tool before reformatting the drive (which will delete any information on the drive). If your external drive isn't listed here, try connecting it to a different USB port. Make sure that your USB ports are providing enough power to the hard drive. (Some USB ports can be disabled for power savings/security.) If you are using a laptop, try plugging in your AC adapter/charger. If you are using a USB hub, try a direct connection to the computer (or use a powered hub).
If you are still not seeing the drive listed, there is a problem with the connections inside the external drive. Either the wiring between the drive and the controller has come loose, the USB connection to the controller is damaged or the drive failed.
If the drive is out of warranty, you can try opening the case and using a different enclosure (2.5" or USB/IDE/SATA adapter). If you have a desktop with a free SATA controller, you could try putting the drive in your system. If the disk works with another controller, the enclosure was bad.
I hope this helps.
Sep 03, 2012 | Verbatim 53018 Store n Go 1TB USB 3.0 2.5...
Not open free space 0 used space 0 not formated USB flash memory
Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Oct 11, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Just purchased a verbatim plug & go 4gig. my machine picks it up bt i get a pop up box asking me to format. when i select the 'format' option it tells me that windows could not format the disk. what's...
What machine do you have? What version of Windows? The USB flash drive is already formatted. Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Oct 08, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I have 0 files in my 250MB Verbatim flash drive, but only 9MB available??
Reformat the drive.
Right click on it and select format then check the capacity of the drive.ü
Oct 06, 2010 | Verbatim VER95327 USB Hard Drive
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Verbatim VER95327 USB Hard Drive Logo
789 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
