Our Monitor MPI 41 model heater won't stay on. It flashes 88:88 in the time/temp window and the Burner status flashes high. When we shut it off (power down) and power it back on it works until it reaches temp, then it stops working and flashes the 88:88 code and 'high' burner status. Can you please tell me what is causing this error and how to reset it? Also, do you know how to get access on-line to a technical manual for the model 41? thanks
  • Brian Niten Dec 31, 2010
    Let me ask a couple of questions to get a better idea of what your heater is doing. Does the fuel pump start making a loud thumping or ticking noise before the heater cuts off? If it does, the fuel pump isn't picking up anu fuel. Watch the room and set temperatures. Does the room temperature get 4 F above the set temp before it cuts off? That is how the heater should work. Have you checked the fan cage behind the heater? If it is clogged with dust and lint, the heater may be overheating from lack of airflow across the heat exchanger. I think they have owner's manuals at www.monitorproducts.com. You need a password to get access to the service manuals.
Mine is getting fuel, but it still clicks off like the original post stated, and its clean. The only other thing .. that water in the tubing. We get a TON of watered fuel here in Alaska! Damn oil venders.
Posted on Nov 01, 2015
SOURCE: BURNER STATUS LIGHTS START FLASHING, SHUTS DOWN!
Not sure exactly what is meant by half way it shuts off. My furnance wouldn't heat to 68 degrees from a setting of 63 degrees on the setback thermostat without shutting down several times with a single flashing led. It would reset after an hour or so until it finally reached the 68 degrees. The problem turned out to be the tube that drains the water from the blower assembly. It had a belly in the middle which would cause the water to sit and block the airflow sensor for the gas value. Lifted tube to allow proper drainage to correct.
Posted on Dec 24, 2008
SOURCE: mpi monitor 422 heat problem
I had the same problem last night and this morning. Its in the manual. I had to take the fan off of the back and vaccuum out all of the dust/lint that built up and it was a lot. It is a safety feature. It's a overheating protection feature that usually triggers if there is build up in the fan, front vent or vent pipe to the outside. I hope this helps.
Posted on Jan 06, 2009
  • 17 Answers
SOURCE: the heater starts to reach
Fuel Fuel Fuel It clicks because the pump is dry
Posted on Nov 17, 2010
bbtoast
  • 319 Answers
SOURCE: shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
Have you looked at, and or followed the troubleshooting suggestions at this website?
There is a full troubleshooting guide for your model. Let me know if you have checked this site out, then give me more details as to any other indications.
How old is this unit, how long has it been plugged in to the current electric outlet, etc.
Thanks
Brian
Posted on Jan 19, 2008
tborn6
  • 700 Answers
SOURCE: fan cycles on and off to often the burner stays on and the fan cy
what is happening is that the heat exchanger has to get to a certain temperature before the fan comes on that way you have warm air blowing out of the grilles and when the heat excahnger gets cool it shuts off until it warms back up again.
Posted on Jan 25, 2009
New Reliance gas water heater won't stay lit
There is a sensor that shuts off the gas to the burner if a flame isn't detected within a few seconds. It will usually look like a tube that extends into flame of the burner. It may be defective or it may just need to be repositioned so more of it is directly in the flame.
Mar 17, 2014 | Reliance Water Heaters
Ihave a 441 monitor kerosene heater,burner status light are flashing and the heater shuts down.the heater has had a turnup, tank filter has been replaced, flow has been checked,igniter or flame dtecti
look and see if the part that stubs out the wick upon turning it off is stuck up or not dis engaging properly. if stuck up the over heating would shut it down!.
Jan 04, 2013 | Heating & Cooling
I have a MPI 41 monitor heater. k-1. runs for a bit and shuts down..88:88 appears as well as the orange indicators do. they flash together. any suggestions. I also had a repair man here twice and still...
How long is a bit?
Sounds like the clock is faulty - Did the repair man disconnect it from the mains? (Turn it off and on again! ;)
Does the clock have battery backup?
Is the mains power steady?
Is the time set correctly?
Does your unit have child lock?
Dec 31, 2012 | Heating & Cooling
My mpi 41 moniter heater will come on for a few minutes and then shuts off and the display window flashes 88:88 plz help!
Do you see any flames before the heater cuts off? If not, check the igniter first. You can check it with an ohmmeter or with a clamp on ammeter. If using an ohmmeter, the igniter resistance should be between 10 - 20 ohms. If using a clamp-on ammeter, clip around just 1 igniter lead and you should get 2 -4 amps.
Does the fuel pump start making a thumping noise before the heater cuts off? It makes this sound when it isn't getting any fuel to it. Check your fuel filter and fuel strainer. Be sure to shut off the kerosene before checking either.
If you do see flames before it cuts off, you need to check the flame rod. Clean it with some steelwool or emory cloth. The flame rod is located next to the window on the combustion chamber and has 1 wire going to it. Unplug the heater before checking.
If this doesn't help, let me know what you have found and I can give you more info.
Jan 05, 2011 | Heating & Cooling
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
Monitor 41 oil heater stove lost its heat...
We repair Monitor Heater main circuit board and push button panel. call me at 800-782-4449 ask for Dima
Feb 01, 2009 | Heating & Cooling
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
2,493 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
